how bad is it to cut half a coil off springs?
Old Apr 12, 2003 | 10:58 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
i cut half a coil off each my stock springs, how bad is this? will it really screw things up?
Old Apr 13, 2003 | 06:00 PM
Marc 85Z28's Avatar
No it won't hurt anything as long as you don't use a torch to cut them. I cut mine and have had nothing but positive results.
Old Apr 13, 2003 | 07:21 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
some one said they will be bouncy but i thought they seemed stiffer the neighborhood
Old Apr 13, 2003 | 07:52 PM
Kandied91z's Avatar
it depends on how many miles are on the springs as well. it isn't to bad on newer springs but old ones it can cause problems. definately make it dangerous at high speeds if you do it wrong.
half a coil shouldn't cause to much of a problem though. just get people laughing at you if your car gets that "floating"effect.
Old Apr 13, 2003 | 09:26 PM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
yep your right but then you just need to get nicer shocks....floating is cause but the spring rate changing so much your shocks cant handle it anymore so they bounce or float so a stiffer set of shocks will cure that....even if there just newer theyll be fine. I have 1/2 coil cut off the front of my DZ lowering springs and even with one bad leaking strut and good knows how bad the other one is (its not leaking or has no more fluid to leak) I still have only a little floating at high speeds over (100kmh say) with crapy side roads with dips and quick hills. But those shocks are going to be gone by wed. so ill get back to ya on if the new shocks cure it ALL up the little floating I do have.
Old Apr 14, 2003 | 12:52 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
i was gonna get KYBs
Old Apr 14, 2003 | 02:11 AM
Kandied91z's Avatar
if you can afford the bilstein hd's they will be the best investment you make.
Old Apr 14, 2003 | 10:31 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
thats the thing im on a budget :-( ill probably end up doin either an eibach pro kit with KYBs or all out bilstein HDs with 2" intrax lowering springs
Old Apr 15, 2003 | 08:17 PM
CR-SuperChevy's Avatar
i took 2 coils of the front and 3 off the back it rides nice.. stiff but still some give really low i love it personally it sucks when someone puts a pencil in the road tho F$%^@ up the ground effects.... hehheheh
Old Apr 15, 2003 | 09:07 PM
Xceleratemaro's Avatar
go with the kyb i put mine on yesterday and nothing but awsome b4 i could push on my front fender and the car would go down and up and down agian now when i push on my fender i go up and the car stays stilll...ha ha ha .....they kick ***
Old Apr 15, 2003 | 09:23 PM
Kandied91z's Avatar
you could put some 30 dollar gabriels and get that effect. anythings better than nothing when it comes to replacing worn out suspension pieces.
personally i have no idea how you cut so much off your coils and not have major problems. i took half a coil of brand new eibachs and it dropped alot. have any pictures with that much cut off?
Old Apr 16, 2003 | 01:19 AM
i have pictures of it but nothing from a far to give u a perspective of the drop im changing the rods over to titanium rods for strengh so its no running its stuck in the warehouse but hopefully in the next couple days i can get it out on the street and snap some pictures for you.. the rims on it are the spares 14's with pretty big rubber on the front and 15's and phat rubber on the back sits like a beast looks like the engine is in the ground. personally i love it the rims well the rubber right now sticks into the fender but ive got 17" american racing aero chromes with 1 1/2 rubber those go on very soon and thell tuck nicely into the fender ive had ppl ask if im on bags...
Old Apr 16, 2003 | 01:45 AM
Kandied91z's Avatar
i would imagine so if you cut that much off. i know if i went that route i wouldn't be able to turn.
Old Apr 16, 2003 | 02:16 AM
actually it turns just fine i havent had alot of time driving it over extensive times but i dont get any tire rub there are no inner fenders i love the ride being low low is amazing gives the car a amazing stance ill get the pictures for u guys
Old Apr 23, 2003 | 03:47 PM
Car: '81 Trans Am
Engine: 6.6L
yah mines preety low i got 1/2" from the top of the tire to the fender lip....and if you have the car on a drive on lift,,,,youll see your front rubber snubs ride right on your frame,,,,, mine are,,,,if those break off youll just get rubing then,,,,but you can make newones that are countersunk holes in some rubbler and bolt them right thru and bolt them to the frame! They last as the stockers just brake and fall off cause there technicly bolted to the frame its just that the rubber is glued to the metal plate that bolts to the frame. I was told my rubbers should fry out sometime soon. Oh well nothing a moded hockey puck wont fix......whhhooo hhhooo got to love CANADA!! hehe
customblackbird
Aug 15, 2021 10:16 PM
TheExaminer
Aug 25, 2015 07:34 PM
Winchester1094
Aug 18, 2015 10:23 AM
TA8487
Aug 11, 2015 09:02 PM
