shakes bad at 90mph
Old Apr 13, 2003 | 08:54 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
shakes bad at 90mph
hey guys i raced my freind tonight and i was doin liek 90 and my car started to shake real bad, i thought i blew my trans up so i threw it into neutral but it still shook and then i reved it a little and nuthin happened so i knwo its not my drivetrain. it has to be something with the suspension or the tires. now if i had out of balance tired woudl it create a shake at 90 or woudl i feel it all the time cause its usually completly fine. thanks guys
Old Apr 13, 2003 | 09:29 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
If the tires were out of balance, or the rim bent it would depend on your speed. If it was just a little out of balance, then at most speeds you wouldn't feel it, but the faster went, the stronger the vibration.
It could be a bunch of things. I'm not expert so I'll say no more.
Old Apr 13, 2003 | 09:57 PM
Jon92TA's Avatar
Car: 92 Trans Am - Sold
You may have just lost a balance weight off a wheel. Usually you can tell if it's the front or the back if your steering wheel shakes a lot or not. Or could be something more serious like worn out susp bushings, bent rim, tire separation, driveshaft out of balance, bent axle etc. I'd check the tires and wheel balance first.
Old Apr 16, 2003 | 09:18 AM
Coqpit's Avatar
Car: Black '91 Z28
Engine: Bone Stock L98
My car does the same exact thing... my problem is a bent front rim. Right about the same speed 90mph it starts to shake.. under that there is no problems, and the car drives in a straight line. So until i find another 16" 91-92 rim i have to deal with it.
Old Apr 16, 2003 | 09:56 AM
Mark W. Winning's Avatar
These cars were also know to have crappy driveshafts that shook at 85-90. Mine did real bad until I changed to an LT1 aluminum shaft.
Mark
Old Apr 17, 2003 | 12:26 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Same as Mark. I had a bad shimmy on my RS and installed a 4th gen alum shaft and the problem disappeared.
I luckily got mine for $70 shipped and installed new U-joints. Install was 10 minutes. I'd balance the wheels and then try the shaft swap.
Ed
Old Apr 17, 2003 | 02:27 PM
oOSpeedFreakOo's Avatar
Accelerate to 120 make it go away!!!
Old Apr 20, 2003 | 01:50 PM
Zeke3Elevn's Avatar
My 91 rs would shake like crazy on the highway at speeds over 80
I got new tires and had them balanced... no problem
Old Apr 20, 2003 | 06:20 PM
Rancid87's Avatar
Check for out of balance driveshafts and weak motor mounts.
92firebirdguy
Sep 1, 2016 07:53 AM
92-Formula
Dec 12, 2015 10:34 PM
88rscamar0
Sep 23, 2015 09:08 PM
gta892000
Sep 16, 2015 12:40 AM
Amillionoh7
Sep 5, 2015 11:44 PM
