lowering my car
Old Apr 20, 2003 | 11:28 PM
RED92BIRD305's Avatar
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
lowering my car
ok i bought a set of 2 inch lowering springs and shocks off of a guy on ebay and i was wondering before i put them in if there was anything else i need to install them like spring seats or some kind of bump stop or whatnot thanks for any replys
Old Apr 21, 2003 | 09:28 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
what kind are they and are they for the front or the rear?
Old Apr 21, 2003 | 10:53 PM
Engine: LO3 and LT1
they are eibach and i have them for the front and rear my front springs already sag a bit so i dont think it will lower the front at all but my bac still sits kinda high so i hope it will just even out the front with the back
Old Apr 21, 2003 | 10:58 PM
Engine: LO3 and LT1
i just was wonderinfg if i need any new suspension parts besides the alignment because i am replacing shocks and struts at the same time
Old Apr 22, 2003 | 12:52 AM
Engine: LO3 and LT1
why doesnt anyone ever reply to this topic for me
Old Apr 22, 2003 | 01:14 AM
CrazyHawaiian's Avatar
Car: too many ...
It would depend on how hard you drive the car. For normal daily driving you wont need anything else besides an alignment. If you take the car roadracing and take turns hard, then you might want to look into correcting the changes in your suspension geometry.
Old Apr 22, 2003 | 01:17 AM
Engine: LO3 and LT1
i line up with people at stop lights once in a while and sometimes break the speed limits on open backroads in the country but not like roadracing on a track what would i have to change if i change the geometry
Old Apr 22, 2003 | 02:18 AM
Car: too many ...
Since you like to drag race I would recommend you also get a set of LCA relocation brackets for around $70 they will correct the angle of your LCA's in the rear. When dropped the LCA angle will change and cause alot of wheel hop. The relocation brackets will eliminate any wheelhop and keep the power on the pavement. If you dont roadrace then dont worry about the front.
Old Apr 22, 2003 | 10:22 AM
Engine: LO3 and LT1
ok not to sound like an idiot but which one of those bars will be the LCA is it the track bar that runs parallel with the driveshaft or the one that goes at an angle and connects to one side of the rear axle
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
