springs and wheel hop
Car: Camaro RS
Engine: L03 305
Transmission: 700R4 Auto
I've got higher rate springs in the rear. Has anyone ever done any work on whether or not the higher the spring rate is the more prone to wheel hop a car might be. I've put everything on my car to eliminate it except for a tubular torque are, they are a bit pricey, and I've still got some, not as bad as it used to be but it makes me think twice about punching it off the line.
Thanks!
Thanks!
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
when you say higher spring rates, did you change ride hieght at all when you changed springs? if you lowered the car at all, it will be more prown to wheel hop.
ambainb
Apr 25, 2016 09:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
