Install tips for the edelbrock 3 point tpi stb?
Old May 2, 2003 | 12:45 PM
MdFormula350's Avatar
The directions are not really good, they say simply put it together; but when to use the silver washers or gold washers?
any helpful tips when installing this stb?
thanks for any help. i ran some searched but i usually just find pics.
also i think i may need to move the cruise control around it kinda gets in the way.
i took some pics of it sitting on the strut towers.
Attached Thumbnails Install tips for the edelbrock 3 point tpi stb?-im000223.jpg
Old May 2, 2003 | 12:46 PM
Attached Thumbnails Install tips for the edelbrock 3 point tpi stb?-im000224.jpg
Attached Thumbnails Install tips for the edelbrock 3 point tpi stb?-im000225.jpg
Old May 2, 2003 | 12:48 PM
not too sure if i like the idea of drilling holes, i dont want it to come out bad and be not centered right.
Attached Thumbnails Install tips for the edelbrock 3 point tpi stb?-im000226.jpg
Old May 2, 2003 | 01:47 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
just assemble the whole thing and put it in place, then mark the holes w/ somthing start w/ a small pilot drill hole and gradually make them bigger. yeh the instructions EDELCOCK has w/ the STB is a joke. good thing its not way too complicated. check out my readers ride if you wana see a pic of my stb.
Old May 2, 2003 | 01:58 PM
when / where do i use the silver washers? i am thinking to mount the main brackets to the strut tower two to each bolt?
does it look like the cruise control is going to be in the way?
i know to assembly it and then mark the oles but how can i have the rear parts assembled and mark holes with the screws in the way?
i dont want to mess this up, might just buy the kenny brown one instead.
Old May 2, 2003 | 02:27 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
It doesn't really matter which washer you use and where. Infact, I threw out all those old bolts and washers and got some stainless steel bolts/washers. I set the main body of the STB BEFORE the actual black strut mount and then made sure the 2 connecting bars fit at my firewall.
The little metal plate goes ontop of the firewall lip, and the stb bars under it. Once I had everything sitting there I just punched the holes, drilled... and started each bolt before tightening down.
Pretty simple. You don't have to measure, just put it there, drill and go.
The Kenny Brown brace you have to drill holes also.
Attached Thumbnails Install tips for the edelbrock 3 point tpi stb?-passsideafter.jpg
Old May 2, 2003 | 02:55 PM
i am so lost now, we just read the directions and it said it not for the formula's, this is so ghee
o well not sure what to do now.
Old May 2, 2003 | 03:29 PM
If you can get 6 bolt holes for it, without having to move your strut mounts... then Bolt it down and GO!
Old May 2, 2003 | 04:44 PM
v8unleashed's Avatar
basically what they said, it's not an exact thing, just get it set good and drill the holes, everything will tighten up when you bolt it down. and if you miss a little bit with a hole, you just enlarge it a little.
but....
make sure you get a GOOD drill bit before you start....it took me like 3 hours and i burned out a drill in the process
Old May 2, 2003 | 06:17 PM
3 hours?! Mine took about a minute a hole!
I recommend taking your hood off to drill the firewall lip holes. Made life alot easier.
Old May 2, 2003 | 06:32 PM
i think i may just buy the kenny brown but it says it fits formula's also, i am not too sure i may just try this one i have to make a decision soon.
rocn7roc
Sep 21, 2021 02:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
