need help quick...my ball joint is moving in the A arm
Old May 13, 2003 | 08:11 PM
86transamws6's Avatar
Car: 88 IROC - 86 Trans Am
Engine: L98 Carbed - 350 Carbed and boosted
Transmission: auto - T5
the auto ecanics teacher said that the hole in the A arm that the ball join goes into is a litle worn out, so its moving up and down, i can either get a new A arm or spot weld it back where it was pressed in he said...will that work?
Old May 13, 2003 | 08:41 PM
ede's Avatar
ede
i've heard of a lot of people here welding it in. i'd rty loctite first. the way it's loaded is pulling it in instead of allowing it to far out, but i'd want to make sure it was secure.
Old May 13, 2003 | 08:54 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I'd get another control arm, I wouldn't fool around with any alternate engineering schemes. They're like $25 at the buzzard. Life (your own and everyone else's around you on the roads) is too short to take chances on it, for $25.
Old May 13, 2003 | 08:56 PM
only 25???
Old May 13, 2003 | 10:17 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
when i went to autozone to get my ball joints they offered an oversize one. might want to try that.
Old May 14, 2003 | 07:11 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
only 25???
Last time I needed them I paid $35 for both.... I was being pessimistic, it's probably less than that. I was changing the bushings, and I wanted to just get another set and do those, so I could take the car apart and put it back together right then without having to deal with the bushings while it was disabled.
These control arms fit something else; A & G bodies, probably. They even still have the shock mount in the middle of the spring pocket, that doesn't belong on one of these cars.
Old May 14, 2003 | 11:11 AM
Steve89GTA's Avatar
Get the oversize set. THey are available everywhere. That's what I had to do - but only on one side for some reason. Make sure they're in all the way!!
Old May 14, 2003 | 09:02 PM
ya its on on side for me too
New2Chevy
Sep 28, 2015 12:35 AM
rb85TA
26
Sep 14, 2015 10:29 PM
Ragtop Man
Sep 12, 2015 12:23 AM
luvofjah
Sep 10, 2015 10:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
