Wheel Bearings and Oil Seal
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Front brakes. I neglected to lube the shoulder that the oil seal fits over. Should I expect problems?
JamesC
JamesC
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Shouldn't be a biggie. Once the grease gets warm it will flow out to the seal area.
Ed
Ed
Car: 1986 Firebird
Engine: 2.8 V6
I assume you know this, but just in case
- don't forget to check the bearing endplay after a few days, when all the extra grease has smushed out. Keep that low torque spec in mind (isn't it 12 ft/lbs) for the spindle nut...
- don't forget to check the bearing endplay after a few days, when all the extra grease has smushed out. Keep that low torque spec in mind (isn't it 12 ft/lbs) for the spindle nut... Supreme Member
Yep, 12 ft-lbs. Then loosen and retighten finger tight and stick the pin in the first hole you come to....uh...yeah...
Ed
Ed
ambainb
Apr 25, 2016 09:21 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
