rattle coming from brakes?
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
whenever i hit a pothole or other imperfection in the road the passenger side brake makes this rattling noise as if somethings loose? is it the caliper bolts that need tightening? cuz i wiggled them around and they seem to have some play in them, other than that i dont know what the noise is but im guessin thats it
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
check your tie rods, i have the same rattling noise sometimes and i also suspected a loose pad but it seems like the tie rods are my problem... not exactly sure yet. u need to tighten those caliper bolts tho in either case ASAP. those things are usually torqued down on there really hard.
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
well i replaced the tierods...unless they're defective? i suspect the caliper because its semi-loose when i push it with my hand it moves...
Try this, I had the same problem. jack the wheel off the ground and rotate it back and forth and you will see (if this is the problem) that the brake pad will move back and forth within the caliper and make the noise. Just look at it and see how you can bend the tabs to stop it from moving. Just an idea.
By the way, im pretty sure the caliper is supposed to be able to move a little, thats why its mounted with pins
Guest
Posts: n/a
Terrell351
Jun 13, 2021 01:13 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
