Sfc's
Sfc's
I UNDERSTAND THAT SUB FRAME CONN. HAVE TO BE WLEDED BY A GOOD PERFORMANCE SHOP OR YOUR CAR WILL LOOK LIKE CIMMANON TWIST? ANYONE KNOW OF A SHOP IN NY THAT DOES THEM THERE WAS A SHOP IN LONG ISLAND BUT I FORGOT I THINK IT WAS IN A GM HIGH TECH ISSUE FEW YEARS AGO.
Car: 1987 GTA 350
Transmission: 700R4/2400 stall
Axle/Gears: B/W 3:27 posi disc
Can you weld? If not take it to the shop. If you can then weld them in. It is not that hard mine took 3 hours to put in, but I have a mig and I know how to use it.
Car: 1987 GTA 350
Put the front tires on car ramps and put two jack stands under the rear axle, as close to the tires as you can. The car is straight. It is just like being on the ground. That is how I did mine and it is straight as a arrow, and it is a vert. Hope this helps.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
luvofjah
Sep 26, 2015 08:28 PM
