Questions on Spare Tire
Old Jul 2, 2003 | 08:23 AM
dp149's Avatar
I have just made my 91 TA into my daily driver. Question is what size rim/tire should I get as a full size spare for the car ? It has the 16 inch wheels with the 245/50R16 tires but I was told the rims are different for front and back. Is there a size rim and tire I can get that could possibly work on all 4 wheels if I get a flat. I have a long drive (50 miles one way) and don't want to rely on the little donut spare they give you in case of emergency.
Old Jul 2, 2003 | 08:27 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
if you get the correct backspacing for the front, it will bolt onto both the front and rear (the rear will stick out a little, but beats a donut
the rear wheel however will not fit on the front.
Old Jul 2, 2003 | 12:18 PM
82camaro's Avatar
Car: 82 camaro SC
You could also get a used 14 inch wheel from an s10 and put a 195/75R14 on it. That will be really close to the same height and take up less room. Should be able to pick up a wheel and tire from a junkyard cheap. Also, it will fit on the front and the back. The lug nuts on your wheels will work without a problem on the steel wheels.
Old Jul 2, 2003 | 01:00 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
The Inflateable Spare ( not the donut one) should work on both the fron & rear and stores in the stock location.
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
69 Six Pack
Oct 5, 2015 07:51 PM
