Strut Lower Bolt Torque
Car: 1988 Camaro Sport Coupe
Engine: 2.8L V6
My GM manual says the lower two front strut bolts need to be torques to 202 ft/lbs. Now how on earth do you do this? I have yet to see a torque wrench go that high. Do you have to use air tools or can you use hand tools? I was thinking of doing it on my own but if I need air tools then I will have to wait till I get some. It seems to me you just tighten them as hard as possible and that's it.
Car: 1986 Firebird
Engine: 2.8 V6
I torqued 'em to the max my torque wrench would go- 150 ft/lbs. Then I let the impact wrench tighten 'em up for a bit past that.
See more info here: https://www.thirdgen.org/techbb2/sho...hreadid=187050
See more info here: https://www.thirdgen.org/techbb2/sho...hreadid=187050 Thread Starter
Engine: 2.8L V6
Yeah I am thinking I will need some air tools I want to get a nice Craftsman Professional compressor and go to work. I am thinking if you take your car to a shop they don't care about torque numbers. If I didn't make a fuss at a shop they would not care about lug nut torque either. I usually end up torquing those again later if a shop messes with them.
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Yep, 203 ft-lbs. Just tighten the hell out of them and use some LocTite. I borrowed a 250 ft-lb wrench to do mine:
Loc-tite? Didn't think of that one! (Damn)
Miller: I like the painted LCA and spindle.
Ed
The Molykote I got from the Navy...
It's just a good brand of anti-seize compound.
www.por-15.com
There is a bit of prepping involved but it's easy.
Ed
It's just a good brand of anti-seize compound.www.por-15.com
Ed
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Howdy
Does any one know if ya can rent 250 lb/ft torque wrenchs at like a pep boys or something cuz I dont have enough money to spend on one!
Kevin
Kevin
I THINK so...you'd have to check with your local store.
Ed
Ed
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
203ftlbs means give it everything you've got with a medium length breaker bar.
You could always use the torque values we used on the submarine I was on a few years back: One ft-lb and two ft-lb...that was it.
"1ft-lb" was to stand on the wrench with one foot, "2" was use both feet, you get the idea, just don't give yourself a hernia..
Ed
Ed
ambainb
Apr 25, 2016 09:21 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
