Better Turning Radius?
Old Jul 22, 2003 | 07:13 PM
logikal6785's Avatar
I've been driving a porsche 944 for a while now, and i can turn that thing around in about a lane and a half. I know that a car's turning radius depends on the wheelbase, scrub radius, turns-to-lock, and tire size ... but isn't there any way to make the thirdgen's make a tighter turn ? I had a GTA with the quick-ratio steering and it still took a 3-point turn on most residential streets .... =/ please help guys
Old Jul 22, 2003 | 11:31 PM
ttt
Old Jul 22, 2003 | 11:44 PM
EvilCartman's Avatar
Car: '82 Z28
Could always put your foot down and swing the back end around
Old Jul 22, 2003 | 11:52 PM
well, that's SOP right now ... but you know, tires get pretty damn expensive =P
Old Jul 24, 2003 | 06:16 PM
Spdfrk1990's Avatar
Thats what i do evil but i was takin my friend for a ride the other day that has a del sol and he was like just do a uey and i was like um sorry cant turn that tight.
Old Jul 28, 2003 | 02:20 AM
ttt ... please guys, a little help
Old Jul 28, 2003 | 04:12 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
You are limited by the geometry of the front suspension. Turn your wheels all the way to the lock, have a friend hold it there, and go look at the available clearances. My guess is you wont find much, and with larger than stock tires, even less. be sure to check both front and back sides for clearance, on both sides of the car as well.
Old Aug 29, 2003 | 01:20 AM
so there are no options besides maybe some crazy retrofit of that quadrasteer off a pickup ?
Old Aug 29, 2003 | 02:29 AM
Car: '82 Z28
Take a wrecked Silverado that has the quadra steer stuffs and make it work on the car
Old Aug 29, 2003 | 06:46 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
And put in a C4 IRS while you're at it....it would be a simple swap compared to the quardasteer.
Old Aug 30, 2003 | 12:49 PM
EDDIETA_ZZ3's Avatar
Car: Trans Am
Engine: ZZ3 HO
Transmission: 700R-4
Put skinny tires in the front and trim the steering stops on the control arms. Of course your handling will suffer
Old Aug 30, 2003 | 01:09 PM
87350IROC's Avatar
Car: 87' IROC
Its just the nature of the beast (without major custom work).
Old Aug 30, 2003 | 03:47 PM
well ... i guess it wouldn't be a firebird without the 18-wheeler turnarounds =P
Old Aug 31, 2003 | 03:00 PM
MY-92-RS's Avatar
Car: 92 CAMARO RALLY SPORT
Engine: 383 sbc w/250 shot of nitrous
Transmission: AMERICAN POWERTRAIN- EXTREME TKX
Axle/Gears: STRANGE ENG. 12 BOLT 3:90 SPOOL
convert to manual steering use gear box for an 85 S-10 pickup
turning radius will be cut almost in half !!! :hail:
Old Aug 31, 2003 | 03:01 PM
MY-92-RS's Avatar
fan belt routing for manual steering :hail:
Old Aug 31, 2003 | 03:03 PM
MY-92-RS's Avatar
New front-end alignment specs for manual steering :hail:
Old Aug 31, 2003 | 03:13 PM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
is the 85 s-10 steering box a bolt in?
Old Aug 31, 2003 | 03:17 PM
MY-92-RS's Avatar
YES use the orignal pitman arm
Old Aug 31, 2003 | 07:11 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Cheapest way to do it...
Turn hard, Floor it, itll spin ya right around!! lol
morrow
Jan 13, 2024 12:29 PM
gta892000
Aug 11, 2019 11:16 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
greenyone
Sep 8, 2015 08:41 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
