Energy Suspension Sway Bar End Links?
Old Aug 2, 2003 | 03:08 AM
GilmourD's Avatar
Confusion is abound here... I keep seeing people differ over whether the 9.8125 (2 3/8") or 9.8117 (2 5/8") sway bar end link should be used for the rear. I have the 9.8125 in my hand as we speak. Should I return it and get the 9.8117? What REALLY makes me mad is that every catalog seemingly ignores the fact that the F-body (and I'm sure many other cars) has both front AND rear sway bar end links. ARG!
Old Aug 2, 2003 | 06:19 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I used the GM 1LE poly end links for my 85 IROC; however, in advance of that purchase, I did look into Energy Suspension. My notes tell me that I was interested in Summit part number ENS-9-8117R (Red), sleeve length 2 5/8.
JamesC
Old Aug 2, 2003 | 01:37 PM
GilmourD's Avatar
Can anybody tell me why I've found mentions of 9.8125?
Old Aug 2, 2003 | 02:26 PM
JamesC's Avatar
Try the following link:
http://www.energysuspension.com/cam1.html
JamesC
Old Aug 2, 2003 | 02:28 PM
GilmourD's Avatar
That link is wonderful and all, but I've looked at that and the actual paper catalog. No listing for a rear sway bar end link.
Old Aug 2, 2003 | 03:30 PM
JamesC's Avatar
Front and rear are the same. The 1LE poly end links that I'm using, for example, front or rear, are listed as GM 10221779. By the way, I much prefer the fashion in which the latter fit in the sway bars and a-arms. You may find that the orginal end links have ovaled the hole the in a-arm. I did a weld and grind before replacing, then after, perhaps fifty miles, I retorqued.
JamesC
Old Aug 5, 2003 | 01:10 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I also used the 2 5/8" sleeve length end links, front and rear. You can always file the sleeve down if you want to tune the sway bars further.
And as James mentioned, when I rebuilt my suspension, I found out that the holes in the lower control arm had indeed "ovalled" out. I was just too fed up/dirty/greasy/tired to weld 'em up at the time.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
