4-wheel disc.Grinding in turns
Old Aug 16, 2003 | 03:36 AM
acidcore86's Avatar
Car: 89 GTA, 09 G6, 03 E250
Engine: TPI 350...Soon to be a 383
Axle/Gears: Borg Warner
It has been doing this for a while now...am fixing it this weekend, provided that I can find what the actual problem is .
Problem is, when I make a turn (only after the car has been warm for some time), I hear a loud grind ( sounds rotational, as in, something hitting the driveshaft or the muffler draging ). I just replaced the front pads and rotors, front and rear stab. links, and shocks. I don't get it....Anyone know what it could be?
Old Aug 16, 2003 | 05:01 PM
Packy's Avatar
is your rear posi perhaps?
if so might be the clutches chattering.
not sure just a thougt,
Old Aug 16, 2003 | 06:46 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
maybe your axle bearing.
Old Aug 17, 2003 | 02:59 AM
acidcore86's Avatar
the sound isn't coming from the axle or the posi
is there any way that the exhaust pipe could be hitting the drive shaft?.....hmmm
it sounds like the muffler or the stabalizer is draging full on the ground..but I'm sure that's not it...duh
replaced rear pads....they were the original pbrs from 89....that didn't fix it...I'm lost....
gta892000
Aug 11, 2019 11:16 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
greenyone
Sep 8, 2015 08:41 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
