Steel brake line question....
Old Aug 20, 2003 | 08:22 PM
aklaim's Avatar
Is there a reason that the hard lines that come out of the master cylinder look like pig tails? AND, is it possible to replace that hard steel line with a braided line? Has anybody done this?
Old Aug 20, 2003 | 09:33 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
they are all twisted like that, so that the lines to the pass side and drivers side, are the same length. i have never seen steel braided replacements myself.
Old Aug 20, 2003 | 09:38 PM
aklaim's Avatar
Why does it matter that they are the same length?
Old Aug 20, 2003 | 09:48 PM
Dewey316's Avatar
Car: 1990 Camaro RS
i wouldn't think it would, <shrugs> as i don't think the rears are the same or even the fronts for that matter.
maybe they did it, because the guys at GM new it would **** as all of , and make us wonder for years i am really suprised the bean counters would let them get away with using an extra 6" of line, so it must serve a purpose, eh
Old Aug 21, 2003 | 07:51 AM
ede's Avatar
ede
no idea the real reason but i always figured it was a vibration/flex connection
Old Aug 21, 2003 | 12:17 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
It allows for flexibility and thermal expansion of the lines. When the bakes get hot the fluid gets hot and that heats the lines which causes the steel to expand....if they weren't spiraled like that they would crack and leak fluid everywhere. You could replace them with braided lines and not have a problem, but good luck findign lines with the right thread pattern.
Line length means next to nothing in a hydraulic system.
Old Aug 22, 2003 | 08:51 PM
laiky's Avatar
vibration and thermal expansion
Reddeath210
Oct 6, 2015 08:20 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Nj1987
Aug 19, 2015 08:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
