welding in my subframe connectors
I am looking for advice on welding in my subframe connectors,
They are the Jegs bolt in type.
Will I have any issues using my MIG welder? I mean will it harm any of the electronics? ECM, Cruise module, ect?
I assume all I have to do is disconnect the battery?
Any other advice will be appreciated.
thanks,
mike
thanks,
mike
i've welded on a lot of differant things with eletronics and batterys and never unhooked anything and never had a problem, but that doesn't mean you won't or can't. unhook the battery and be a little safer maybe.
Car: check
Engine: check
Transmission: check
I always place the ground clamp as close as possible to and on the piece I am welding. This keeps the current flow confined to that area. With that I haven't had any problems. If concerned teh ECM unplugs easily.
An example of doing it incorrectly would be to place the ground clamp on the exhaust as the subframes are welded in.
RBob.
RBob.
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Make sure you pull up the carpet. This includes removing the insulation.... I used a putty knife to scrap it off the floor. I got away with just sliding 2x4s under the carpet and insulation (after I pulled up all the insulation stuck to the floor) so it kept them off the floor... The sheet metal will get cherry hot for migging them in.
Unhook the battery and everything should be fine.
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
anyone care to help me....?
i bought comp engeneering weld in subframe connectors. all they are is two long pieces of square tubing and a plate with two bolt holes at one end on each connector. how do these things weld up and fit? im going to try and weld them myself but i dont even know how they line up....pictures would be excellent
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
