Problems turning hard left
Old Sep 19, 2003 | 10:46 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
When I turn hard left to turn into a parking spot or something it feels like I'm going over a bump or two. I've only noticed this when turning hard to the left and going very slow. What is this?
Old Sep 20, 2003 | 12:28 AM
Morley's Avatar
Sounds like it may be your front tire sliding/jumping sideways a bit (mine does this when the tires are worn down pretty far)
Old Sep 20, 2003 | 12:34 AM
They have good tread tho....maybe a camber issue? I dunno...I haven't done anything to the front end that would have changed that
Old Sep 20, 2003 | 12:51 AM
Morley's Avatar
Could be sand or gravel causing the tire to slip...other than that..could be an alignment issue
Old Sep 20, 2003 | 01:06 AM
could be sand or gravel I guess. The alingment thing is what is puzzling me because it goes almost perfectly straight, and if it was an issue, alingment would be off. But this thing has happened 3 days in a row now when I was parking and pulling out of my spot at school.
Old Sep 20, 2003 | 11:39 PM
Jon92TA's Avatar
Car: 92 Trans Am - Sold
Sounds like your idler arm is worn out and needs replacement. Mine felt the same way. Check out all the steering components while you're at it.
Old Sep 20, 2003 | 11:57 PM
Morley's Avatar
Check your wheel bearings too while you are at it.
db057
Aug 22, 2015 08:17 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
