98+ Camaro "LS1" brake rotors:
Old Oct 20, 2003 | 12:17 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i was told that these cars all use the same rotors:
00-02 BUICK Le Sabre w/ 16" wheels
97-00 BUICK Park Avenue
97-99 BUICK Riviera
97-02 CADILLAC Deville, Eldorado
97-02 CADILLAC Seville
98-02 CHEVROLET Camaro
00-02 CHEVROLET Impala
00-02 CHEVROLET Monte Carlo
97-02 OLDSMOBILE Aurora
98 OLDSMOBILE Intrigue Heavy Duty
00-02 PONTIAC Bonneville, Catalina Executive SSEI, SLE Model
98-02 PONTIAC Firebird, Formula, Trans Am
does anyone know for sure about any of these? if thats true, what about the calipers? and if i got new rotors for a new impala would they work with the 98+ fbody brake swap??
Old Oct 20, 2003 | 12:35 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
You can use this site to check the part numbers and see:
http://www.gmpartsdirect.com/partsvoice/frameset.cfm
I have also noticed most of gm’s new cars are using the same brake design. It also seems like a lot of fords use the same design.
It’s important to note that though some of these cars may use the same brake pads that does not mean the calipers are the same.
Old Oct 21, 2003 | 11:03 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I'll look into it...
Ed
Old Oct 23, 2003 | 03:07 PM
ebmiller88's Avatar
Well, according to www.rockauto.com, the answer is yes, they are all the same, and priced VERY well too, BTW.
Ed
Old Oct 23, 2003 | 03:08 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Ed
thats GREAT!
Old Oct 24, 2003 | 10:37 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
According to the part search on gmpartsdirect.com none of these cars have the same caliper part number as the F-body LS1 brakes. So I would assume that means they are different but I have not way of knowing with out a side by side comparison.
Here’s what I came up with:
Camaro \ Firebird 1998-2002
Front,Left 18042491
Front,Right 18042492
97-02 CADILLAC Deville, Eldorado - Front Left: 18046196
97-02 CADILLAC Seville - Front Left: 18046192
00-02 CHEVROLET Impala - Front Left: 18046196
00-02 CHEVROLET Monte Carlo - Front Left: 18046196
97-02 OLDSMOBILE Aurora - Front Left: 18046196
98 OLDSMOBILE Intrigue Heavy Duty - Front Left: 18046196
00-02 PONTIAC Bonneville, Catalina Executive SSEI, SLE Model – Front Left 18046196
Old Oct 24, 2003 | 10:40 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
hmm... 18046196 popped up so much that id really like to know what that one looks like.....
Old Oct 24, 2003 | 11:26 AM
84406's Avatar
Car: 84 Z28
Engine: 355/460hp
Transmission: glide\ford 9"
I can't be poss but I think this might be what you are looking for.
Attached Thumbnails 98+ Camaro "LS1" brake rotors:-im1.jpg
Old Oct 24, 2003 | 12:22 PM
ebmiller88's Avatar
Yeah, those would be for the standard brakes. The non-LS1 cars would have got those pictured above...correct?
Ed
Old Oct 24, 2003 | 01:17 PM
84406's Avatar
Car: 84 Z28
Engine: 355/460hp
Those are the GM 18046196 for Dudes post above. The camaro has same calipers whether ls1 or not. That is what others have said and from what I have found.
Old Oct 24, 2003 | 01:28 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
heh, thanks....
athought i dont think thoes are what we're looking for.... i guess i'll just stick to the Fbody calipers.
Old Oct 24, 2003 | 02:02 PM
84406's Avatar
Car: 84 Z28
Engine: 355/460hp
Just to clear things those are not the camaro ones and are not the ones we want. Those do come on some other chevies that use the same rotors as the camaro.
Old Oct 24, 2003 | 02:19 PM
ebmiller88's Avatar
So the rotors would be OK, just not the calipers.
Ed
Old Oct 24, 2003 | 02:34 PM
84406's Avatar
Car: 84 Z28
Engine: 355/460hp
That is what I think.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
