14 mm bubble flare brake line
Old Oct 28, 2003 | 10:30 PM
camaro03's Avatar
Car: 1982 camaro
Engine: built 355 chevy
Transmission: th 350 w/ 3.73 gears
I am currently doing a rear end swap and a disk to drum conversion, and the problem i have is the proportioning valve that i got is made for bubble flares, that you cant find anywhere. I got all of the brake lines on it except for the one to the rear brakes, i cant find a 14 mm bubble flare for it anywhere, and my stock on is 82 style with traditional threads. anyone else have this problem? how did you over come it? thanks
Old Oct 29, 2003 | 03:35 AM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
try using a normal flare?... btw why are you going from disk to drum?!?
Old Oct 29, 2003 | 05:17 AM
ede's Avatar
ede
you sure you need a 14mm? that'd be over a 1/2" usually brake lines are more like 3/16ths and 1/4. at any rate adapters aren't hard to find so you can go from bubble to double flare or you can buy a bubble tool and make your own lines
Old Oct 29, 2003 | 02:51 PM
camaro03's Avatar
Car: 1982 camaro
sorry, i was a little mad when i wrote that, i meant drum to disk, everywhere i went had them up to the size under that, and it was 14 mm, the guy i bought the proportioning valve off of is going to send me the one i need, his name is Joseph van Camp, and i highly recommend him for camaro/firebird parts
Old Oct 29, 2003 | 03:59 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Pep Boys has pre-flared brake lines... but they don't know about them. I have to walk in back (by myself and nobody stops me- ha!) by the tires, and the lines are hanging from a rack. What's funny is the ISO bubble flare lines are hanging from the "foreign/import cars" rack- even though GM has used them since 1984.
You can also buy an ISO bubble flaring tool, check out http://www.toolparadise.com . I tried to find one locally- to buy OR to rent, and was SOL- no store had even heard of it.
Old Oct 29, 2003 | 09:35 PM
Spdfrk1990's Avatar
I got a question r those brakes lines needed on the rear to go into the earl hoses. I dont think i used them when i got new lines that r on it now going into the rubber hoses. I doesnt leak tho i think i might look at pep boys tho when i switch to the pbr's cause i want it done right.
Reddeath210
Oct 6, 2015 08:20 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Nj1987
Aug 19, 2015 08:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
