Lowering Springs: Pro Kit ?
Old Nov 3, 2003 | 01:27 PM
Kleen RS's Avatar
Car: 92 25th Anniversary RS
Engine: A slow one. The infamous 305 TBI
Transmission: 700 R4
I was thinking of going for the Eibach Pro Kit. How well does this stiffen up the ride and tighten the steering?
Old Nov 4, 2003 | 02:36 AM
MdFormula350's Avatar
they are suppose to add handling and give alittle bit of a lower stance/center of gravity. they should add a positive steering feel within the new body roll limits.
prokit added with ws6 sway bars and a wonderbar should be a very nice handling package for your car.
Old Nov 4, 2003 | 06:20 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
The springs won't do a thing with the steering. They do give you a much firmer ride and great handling. Buy them.
Ed
Old Nov 4, 2003 | 07:37 AM
Steve89GTA's Avatar
My Ws6 springs are pretty damn stiff. I get ZERO body roll heck, I can barely push down on the front fender at all to get them to compress. I also feel EVERY little nibble on the road.
Will the prokit be an improvement both in handling and smoothness. I've heard that they are progressive unlike the stock springs which have left a few users unhappy. They complained of the car loosing some precisness by going to a progressive spring...
Old Nov 4, 2003 | 12:11 PM
Kleen RS's Avatar
Cool deal. Once I get some flow, I should be ridin low.
Old Nov 4, 2003 | 02:20 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
my car had original WS6 springs that had about 100,xxx miles on them when i replaced them... put in the prokit along w/ KYB shocks/struts and trust me the car is a completely new car. it handles a ton better and the ride is exactly what i wanted. not too stiff but stiff enough to feel like the suspension has been modded. already had the WS6 sway bars and a STB. Now i take on/off ramps at almost twice the recommended speeds w/ no problems. body roll is virtually non-existant (its there and i can tell it but compared to stock its not).
IMO i would do the swap... you will enjoy it!!!
Old Nov 4, 2003 | 02:25 PM
Steve89GTA's Avatar
Now that's what I wanted to hear! Nice to hear it from a fellow 89 GTA owner as well. Got any pics of your ride? I already have poly bushing, KYB GR2's front and KYB rear, and some spohn suspension components.
Did you go with relocation brackets when you added the pro-kit? Notice any loss of traction?
Thanks for the help!
Old Nov 4, 2003 | 02:31 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
i am at work so i can't post any pics... come to think of it i don't know if i have taken any since the swap. i will try and get some this week and post them for you. no, i did not add relocation brackets after the swap, but then again i don't have aftermarket LCAs, but when i do get some i will get relocation brackets as well. Traction... i actually fell the car gained some traction when i did the swap, but then again my suspension was so worn out that the car almost squatted to the ground upon launch. i picked up about a .2 at the track the week after the swap in similar weather so i think it helped me out a ton.
Horridbulldog
Wheels and Tires
Feb 13, 2016 07:22 AM
Americanmouse
Sep 7, 2015 12:10 PM
Ducati900ss
Sep 2, 2015 09:05 AM
Dialed_In
Aug 20, 2015 01:45 PM
