Any difference between GTA and IROC sway bars?
Old Nov 12, 2003 | 10:33 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I wanted to put my old (140k mile) swaybar from my GTA on my IROC. Is it any bigger? Or did they come w/ the same size sway bars.
Old Nov 12, 2003 | 12:41 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
They should have came with the same sizes.. The IROC's IIRC got the same WS6 size sway bars (36 mm front / 24 mm rear)... The earlier ones _might_ have been smaller (85, 86?).. Some of the IROC's also came with the wonderbar (thats what I got mine off of at a junkyard, never seen a factory t/a with one)...
Old Nov 12, 2003 | 12:43 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
negitory.
the largest IROCs came with 34mm/23mm combo.
if your gta is a WS6 it should have the larger 36/24 bars. if it is non-ws6 they will be equal or smaller than the irocs, depending on the options of both cars. best bet it to measure the bars on each of them.
Old Nov 12, 2003 | 12:56 PM
MdFormula350's Avatar
yup Dewey316 is right.
and then to even more confuse some where hollow / solid depending on size.
measuring is indeed the best bet.
Old Nov 12, 2003 | 01:04 PM
thirdgen88's Avatar
Car: 1995 Corvette
Hmmm.. perhaps the IROC I found at the junkyard a few years back already had been upgraded...
Old Nov 12, 2003 | 01:08 PM
Dewey316's Avatar
Car: 1990 Camaro RS
only ws6 and 1le cars got the 36/24 bars. i would say either you messured slightly wrong, or the car had the sway bars replaced.
Old Nov 12, 2003 | 02:51 PM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
Yes, the GTA is a '91 WS6 and the iroc is an '85. The GTA doesn't have a use for the front sway bar so it was sitting w/ no real use. I guess I'll throw it on the IROC.
Old Nov 15, 2003 | 06:36 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Some Firebirds from 86-92 had the 36/24 combo, some Camaros from 89-92 had them (I found a set on a late-model RS once). My 85 IROC came stock with a solid 34/24 combo, which I've since upgraded.
JamesC
Old Nov 15, 2003 | 11:14 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
You need to realize that your dealing with 10-20 year old cars... anything could have been changed on them and youd never know it. Camaros never got the 36/24 sway bars.
Old Nov 16, 2003 | 12:28 AM
Dewey316's Avatar
Car: 1990 Camaro RS
yes they did, the 1le cars did get those bars. along with springs that were stiffer than the ws6 cars. a late model RS **could** have been a 1le b4c car. and possible had those bars from the factory.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
mustangman65_79
Aug 11, 2015 03:17 PM
