Alston SFCs, got a problem
Old Nov 15, 2003 | 09:52 PM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Has anyone experienced a tough fit on the passenger side Alston bolt-in SFCs? I got them through Lon @ TDS on the GP and it seems like it may have slipped in the jig because the front mounting cup seems to be tilted 10-15* outward.
The driver's side fit in like a glove, but I've fought with the passenger side for a couple of hours right now with no luck. If I was welding them I'd have no problem cutting it off and trying to re-fab it, but I'm just bolting them on for now [only have a wire feed, no MIG].
Any hints are definately appreciated. Thanks guys.
Old Nov 16, 2003 | 08:27 AM
icecold's Avatar
Car: 1990 formula
Engine: 350 tpi supercharged
Transmission: 700 r4
mine also fit tuff but they were definatly not that far off. i had to put a floor jack under mine after i pounded it some in the vise (to open up the cups)then it slid on but still isent all the way on .
pete
Old Nov 16, 2003 | 11:25 AM
ckeene502's Avatar
i had the same problem on the passenger side. on two camaros with the same set of sfc.
keene
Old Nov 16, 2003 | 05:34 PM
nape's Avatar
Where did you guys buy them and when?
Just trying to figure out of it's a new problem. Alston supposedly changed the setup recently.
Old Nov 16, 2003 | 10:25 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
i had fitment problems with my alstons to, alston makes em, ud have to talk to them any other place u buy them from is just a distributer.
Old Nov 17, 2003 | 07:24 AM
Redbird87's Avatar
Engine: 355
Alston fitment problem
Has anyone contacted Lon to see if this is an isolated problem with just this batch? Dave
Old Nov 17, 2003 | 10:20 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
i did, i dont want to start any problems but. i was told... "no one else has complaind about fitment problems with these SFCs, your car could have possibly been in an accident that tweaked the subframes and to contact alston because TDS only distributes them and doesnt manufacture them, never heard anything from alston tho"
Old Nov 17, 2003 | 12:07 PM
drop-top IROC's Avatar
Engine: 305 TPI (LB9)
Transmission: WC T-5
The only problem I had (if you can even call it that, since it wasn't even that big of a problem) was getting it up over the exhaust on the pass. side. It fit the frame rails snug, which it should, but a rubber mallet was all that was needed to get 'em on for welding.
Bought 'em from Lon in 9/2003.
Old Nov 17, 2003 | 08:53 PM
mewaddy's Avatar
Car: 1983 Camaro Z28
Engine: 305 H.O. 5.0L
new guy here, thought i'd thrown in my two cents. ran into the same problem on passenger side of my 83. floor jack under the mounting cup of the sfc seemed to do the trick though, squeezed them right in place.
Old Nov 19, 2003 | 05:40 AM
nape's Avatar
Thanks for the tip. I'll give it a shot if I don't hear from Mike @ Alston soon. I figure if I have to drive to Alston to swap out connectors, I might as well see how much they want to weld them in.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
