pulling to the left
Old Nov 30, 2003 | 03:51 PM
GNR4EVR's Avatar
pulling to the left
I have a '91 GTA, front disc rear drum brakes, and ever since I got the car back in March, it's had a problem with pulling to the left when the brakes are applied.
I've since replaced the front rotors, brake lines, calipers and pads, but the problem persists.
Any suggestions?
Old Nov 30, 2003 | 05:28 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
It only pulls on braking?
Old Nov 30, 2003 | 08:11 PM
GNR4EVR's Avatar
Yes.
The car stays pretty straight during normal acceleration or riding along, but tends to pull just ever so slightly to the right. But when the brakes are applied, depending on how hard they're applied, the car will pull hard to the left.
Old Nov 30, 2003 | 08:17 PM
JR86-TA's Avatar
Car: '86 Trans Am
I had a very similar problem with my car when I first got it. But mine was the opposite and a little worse. The right front brake would sometimes stick, and pull the car to the right. But, even when it did not stick, whenever I would press the brakes, the car would still pull that way. I just replaced everything, brake lines, calipers, brake fluid, brake pads, brake booster, and master cylinder. One of those fixed the problem. Not sure which though. I guess that didn't help much did it? Sorry.
Old Nov 30, 2003 | 08:26 PM
GNR4EVR's Avatar
Well, I replaced all of those except the booster and master cylinder, and nothing changed. So if nothing else, we've narrowed it down
Old Nov 30, 2003 | 11:32 PM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
could a warped rotor be causing the pulling? my car did the same thing, but it turned out to be the brake line.
Old Nov 30, 2003 | 11:50 PM
GNR4EVR's Avatar
I don't think so, I replaced both front rotors and nothing changed.
Old Dec 1, 2003 | 05:31 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
When you installed the new calipers did you make sure you lubricated the slide bolts? If they are not lubed they could seize and not apply brake pressure evenly and that could cause a pull. Just a thought...
Vintageracer
Jan 10, 2020 05:33 PM
bdads
Aug 24, 2015 06:01 PM
Bert87
Aug 23, 2015 03:50 PM
mizz0313
Aug 12, 2015 06:45 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
