Eibach or IROC?
Old Dec 1, 2003 | 01:12 PM
lowbgtRS's Avatar
Car: 94 Camaro
Engine: 383 Stroker
Eibach or IROC?
Which springs will give me better handling, 86 IROC springs or an Eibach kit (Sportline or Pro Kit?)
Old Dec 1, 2003 | 01:17 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
probably the eibachs, the irocs are most likely very worn out.
Old Dec 1, 2003 | 01:48 PM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
using worn springs is almost as stupid as using a worn oil filter.
Old Dec 1, 2003 | 03:56 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
I think he means new OEM replacement Springs for an 86 Iroc.
The Eibachs will be better than new OEM stuff, but they require that you lower your car a little. Unless you compensate with some sort of spring spacer (there a specific term I am looking for?)... if you lower the car by using the Eibachs, you might decrease handling quality a little until you get lower control arm relocator brackets & complimentary shocks/struts.
Old Dec 1, 2003 | 03:59 PM
Dewey316's Avatar
Car: 1990 Camaro RS
IMHO you are better of with OE replacements, that are trimmed
there is a thread where chickenman gives a good rundown on it, i will search and try to find it.
***EDIT****
Here is thread from chickenman.
https://www.thirdgen.org/techbb2/sho...hreadid=200000
Old Dec 1, 2003 | 04:46 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I've heard great things about Moog replacement springs but I don't know the part numbers. Supposedly just as stiff as stock Iroc springs but cheaper than the Eibachs.
FYI, I'm running Eibach Pro-Kit springs and I LOVE them. Can't go wrong there either.
Ed
Old Dec 1, 2003 | 10:13 PM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
how fats can uturn a corner with eibacjs and lcas and shock/strut?
Old Dec 2, 2003 | 12:11 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
You mean without losing tire to ground contact (not necessarily bad)?
"how fast" is a vague question... hard to answer. However, it breaks down like this kinda:
a.)
lowering springs - lowered center of gravity
b.) upgraded shocks/struts - more tolerance and resistance of force
c.)
boxed lca's and lca relocator brackets - better transfer of weight/ compensation for lowered center of gravity
This is only a rough explanation at best, but basically those three components compliment each other and would result in much better cornering over a stock setup ("how fast" you can turn or pull a full U-turn from a stop)
Old Dec 2, 2003 | 08:44 AM
nolanr0413's Avatar
Car: Trans am
i got sportlines and they are great for the looks, but the car seems to handle a little worse than it did before , but when i changed the springs i changed the rear end and lca and panhard bar and put relocation brackets.The rear end weight probably 75 lbs more , so i dont know but i like how the sportlines look.
Old Dec 4, 2003 | 09:52 PM
lowbgtRS's Avatar
Car: 94 Camaro
Engine: 383 Stroker
Alright...thanks for all the help.
Old Dec 5, 2003 | 09:58 PM
laiky's Avatar
I hated my eibach prokit, they are softer than stock iroc springs and lower so the end result was that over bumpy pavement you were on the bump stops. I followed chickenman's advice and got moog 7665/7662 combo for 100 bucks and i am much happier. The only drawback to the moog's is that they must be cut to lower the car, as sold they will be the stock ride height.
NORTz89
May 20, 2020 03:51 PM
deracer
Apr 11, 2016 12:04 AM
Horridbulldog
Wheels and Tires
Feb 13, 2016 07:22 AM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
mustangman65_79
Aug 11, 2015 03:17 PM
