spohn adj lca question
Old Dec 3, 2003 | 04:53 PM
mgilorma's Avatar
Car: 90 RS
Engine: 305 TBI - LT1 Cam
Axle/Gears: Stock Crap
I got these for my car with poly ends, and the rear noise was a little much, i was wondering if there was any quality rubber bushings i could get put in there?
Old Dec 3, 2003 | 10:19 PM
25THRSS's Avatar
Did you grease them up real good?
Old Dec 5, 2003 | 08:42 AM
MdFormula350's Avatar
I was also thinking did you over tighten the bolts maybe, i did (didnt have a torque wrench at the time) and the metal on each side pushed against the poly bushings alot and made them so compact they made noise and where stiff. some greese on the side helped some also.
Old Dec 5, 2003 | 12:15 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
also make sure you jam nuts are tight, then put some lock-tite on them.
reason....
this is what happens if a jam nuts loosens.
Old Dec 5, 2003 | 04:27 PM
Zerstörer's Avatar
Car: 1992
Engine: 350TPI
reason....
HORRORS!!
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Irocguy01
Sep 28, 2015 02:03 PM
redmaroz
Aug 16, 2015 11:40 PM
