Torque Arm
Old Dec 21, 2003 | 01:56 PM
Bink's Avatar
Car: 83 Z 28
Torque Arm
Is anyone here running an Adjustable torque arm? Has anyone noticed any traction gain by putting one on there car?
Old Dec 21, 2003 | 02:41 PM
MdFormula350's Avatar
the one that hooks up like stock? or ones that mounts to the frame?
i have the spohn that uses a new crossmember, which takes the torque arm off the tranny, i definitely put more power to the tires now, still cant hook up as i would like (drag radials would fix that) but has definitely took any flex away and makes the power go to the tires. worth it in my opinion.
Old Dec 21, 2003 | 06:47 PM
Bink's Avatar
Car: 83 Z 28
I am running a home made torque arm made out of seamless tubing. It mounts to a braket that come off my trans cross member. It has a hyme joint with a bolt going through it. It is mounted to my rear by custom made brackets. The bar is solid mounted to the rear, and solid mounted to the cross member. I thought the stock bar was set up so it could slide back and forth, had some sort a give/ motion that would happed when the rear was planting the tires. I am trying to figure out if I should modify mine so it can move back and forth when I launch/ transfer weight and the rear tries to plant.
Old Dec 21, 2003 | 07:09 PM
10.90streetcar's Avatar
Theres more to making these cars hook than just installing an aftermarket T/A. After all this car still uses the Stock Stamped Steel Piece.
VIDEO CHIC
Old Dec 21, 2003 | 07:24 PM
Bink's Avatar
Car: 83 Z 28
Please go into some detail please. My best 60ft. is in my sig. I am also running seamless tubing lower control arms that are adj. back and forth. I have welded in sub frames, and am in the process of installing a 8 point cage. Please go into some detail on your suspension.
Old Dec 21, 2003 | 07:33 PM
Rear is a bolt in 9in from Moser with 4.72 gears and 29.5 x 10.5 x15 m/ t et drags. Boxed LCA with Relocation Brackets, Hal QA1 shocks, Stock springs and Stock Torque Arm. There is also a weld in anti roll bar in the rear. The front end is completly stock with junkyard v6 springs.
Old Dec 21, 2003 | 08:12 PM
Bink's Avatar
Car: 83 Z 28
Do you have anypics, and where did you relocate the lower control arms? To a lower spot on the rear end??
Old Dec 21, 2003 | 10:11 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
I have a jegster,it's not adjustable and bolts to the trans/driveshaft tunnel with a mounting plate that comes with it.
So far I've had good luck with it,I run 26x11.5x16 ET Streets on stock wheels all around(and drive them everywhere including to and from the track)and am consistantly in the mid 1.5's on pumpgas and high 1.4's on racegas.
10.90streetcar, nice pic Willing to share a little more info like best ET/60ft?Motor/tranny?With 4.72's and 29.5" tires your 60ft's must be killer,at least considering my best of 1.47 was done with 26" tires and 3.08 gears.Maybe next year when I go to 28's and 3.42 gears I'll get some better 60fts
That belive it or not is how my car launches no matter if I get a 1.47 60ft or a 1.65
Steve
no green
Jan 9, 2016 09:22 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
