Spohn Torque arm question
Old Dec 23, 2003 | 06:25 PM
Blitz's Avatar
Engine: 383 on the way
Transmission: Tremec T-56
Hi all, This is my first post. I've been lurking around the fourms for a couple months and I finely decided to sign up... Anyway, my question is this: I just bought a Spohn Aftermarket T-56 X member and was looking at the torque arms tonight and found that its a kit that comes with the X member. Does this mean I'll have 2 tranny X members?. I could'nt find the answer using the search but I did'nt look all that long
Blitz
Old Dec 23, 2003 | 07:49 PM
chrissy's Avatar
Blitz:-
Yes you now have two transmission crossmembers, but you won't be using them both at the same time! The stock one is discarded. Just the same way your old torque arm is discarded.
For any others wondering about the parts in question:-
Spohn Adjustable Torque Arm - Aftermarket T-56 Trans. Item: 322
$375.00 is for installing a Tremec aftermarket T-56 transmission into a Thirdgen. The kit includes the transmission crossmember required to install the Tremec T-56 transmission, along with their crossmember mounted adjustable torque arm.
The other part Spohn offer is Adjustable Torque Arm - T-56 (from 93-97) Trans. Item: 315 $375.00.
Spohn part T-56 Transmission Crossmember ('93-'97 T-56) Item: T56XM $110.00 is the Transmission crossmember for the installation of a 1993-1997 F-Body T-56 transmission into a Thirdgen. It is only for those who will re-install the OEM torque arm.
Old Dec 24, 2003 | 10:43 AM
91Z28-350's Avatar
If you call/get in touch with Spohn, he may be able to sell you the torque arm x-member separate from the torque arm. That's entirely up to him though....or you can cancel the x-member and just order the torque arm setup.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
