drum to disc.
Old Dec 29, 2003 | 06:20 PM
SeanTimothy's Avatar
drum to disc.
ok...as of now i have a 91 rs with the stock rear with drums.
i found a rear with discs, eaton posi trac, and 3.73 for 500.
what all is needed to convert from Drum to Disc. Is it *hard* or fairly simple.
AND is 500 a good price for this? i wasnt expecting to pay more than 300 for a posi 3.73 rear end....
Old Dec 29, 2003 | 06:41 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
i guess thats not bad. are you swapping brakes, or the whole rear? i'd personally just swap the rear
Old Dec 29, 2003 | 09:10 PM
swapping the entire rear....im trying to avoid having to install gears myelf,, and find a rear with 3.73s...
what model s10s came with 3.73, 28 spline? 88+ manuals???
Old Dec 29, 2003 | 11:23 PM
IROC-Z2814's Avatar
500 sounds a little steep to me The conversion is pretty easy BUT besides just swapping the rear end with the discs on it, you have to swap the combination valve right below the master cylinder because there is a difference between the two. Also I'm not sure but you might need to change the parking brake cables but I am not sure on that.
Old Dec 30, 2003 | 12:28 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
I believe you will need the e-brake cable, master cylinder and proportioning valve from the car with discs to convert from drum to disc. Someone will correct it if I am wrong...
Old Dec 30, 2003 | 01:02 AM
joshwilson3's Avatar
Old Dec 30, 2003 | 01:50 AM
Z28guy83's Avatar
Car: 83 Z28
Engine: 400sb
I HAVE A DISK TO DRUM
??????????? can i take the discs (and everything off my 9 bolt) and put them on a 10 bolt drum brake rear (the 10 bolt has better gears) and i can get better ones for the 10 bolt installed for what i would cost for the 9 bolt
Old Dec 30, 2003 | 06:46 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
correct me if im wrong but didnt s-10s come with lockers? If im right you might wanna go with a real posi.. lockers are kinda annoying hehe
Old Dec 30, 2003 | 06:55 AM
Pat Hall's Avatar
Re: I HAVE A DISK TO DRUM
The only thing different between the 9 bolt and 10 bolt disc rears is the backing plates that the calipers mount up to. You could router out the holes on the 9 bolt plates to fit your 10 bolt, but 10 bolt backing plates are so common, I'd just pick up a used set of them somewhere. If your 10 bolt is a drum setup, you also have to modify the axle flange a little bit where the backing plate bolts up. I've seen a tech post on here somewhere on how to modify that. Basically you have to cut off the top portion of the mounting flange and drill two more holes in it to mount the disc backing plate. To 89RS: The S10's did use a locker, or Gov-Loc unit, which I've heard breaks quite easily and isn't very reliable. You'd be better off running a rebuildable eaton posi unit instead.
Old Dec 30, 2003 | 09:08 AM
ew s10's came with lockers?? im trying to avoid having to tear into the differential all togather...
i have a slp posi that SHOULD of been here by now....and i have my 3.73s on my desk as we speak....IF i can find a rear end for 300 - 400 ill sell the gears and posi for something like 200....
OEM GM gears...used, but in great condition....
i may just swap out the gears in the rear end i have, i have been looking for awhile for a 3.73 rear and they are hard to come by
500 is seriously steep, i was hoping to jew him down to 400....cause 400 is all i got.....
Question, IF i do swap in the gears myself, should i get the mastyer install kit and put all new bearings in or should i cheap out and pay 34 dollars and get the simple install kit....
Old Dec 30, 2003 | 12:40 PM
Old Dec 30, 2003 | 06:11 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
it took a couple weeks for mine to arrive from slp
Old Dec 31, 2003 | 12:42 AM
Originally posted by joshwilson3
Actually the Master Cylinder that he has on his car for disc/drum will be fine for the disc rear he is gonna put in. But he will need the proportioning valve from the disc/disc car that he is getting is rear out of.
Thanks for clarifying that for me Josh. I knew I had part of it right. I have not gotten to my rear yet as I am still working on the motor aspect of my project but I will be switching over to disc as well.
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
92projectcamaro
Dec 8, 2015 12:25 AM
Prodigious
Sep 18, 2015 05:23 AM
Prodigious
Sep 18, 2015 05:18 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
