Any Suggestions on making my 87 IROC less noisey on rough pavement?
Old Dec 30, 2003 | 05:10 PM
xxxman's Avatar
Car: 1987 IROC Z-28
Engine: 350 5.7
Axle/Gears: Borg Warner
[IMG][IMG]C:\Documents and Settings\Paul\My Documents\My Pictures[/IMG][/IMG]
Old Dec 30, 2003 | 06:01 PM
MdFormula350's Avatar
is it all stock? how many miles?
noisey usually deals with, shocks, struts, possibly springs and somewhat for tires.
does the noise seem to be coming from the interior? or under the body?
Subframe connectors will keep body flex down which should lessen overall noise made from interior parts moving and other things..
Old Dec 31, 2003 | 01:36 PM
xxxman's Avatar
Car: 1987 IROC Z-28
Engine: 350 5.7
Thanks for the input. It's not all stock, 350, high performance cam, headers to name a few. New but cheap shock in the back. Will do the struts and a panhard bar next. Body has 130000 miles on it. Noise seems to come from the windows(in the form of a window rattle) and the rear hatch which I just put in a new pull down. I have a new door hinge on the way. Think I should go with new springs AND struts.? Please let me know what you think. I'll try yo get a picture up.
Old Dec 31, 2003 | 01:55 PM
conlinj's Avatar
get some good tires like firestone indy 500's i have 4 sets and swear by them
xxxman's Avatar
Car: 1987 IROC Z-28
Engine: 350 5.7
Added a pic
Attached Thumbnails Any Suggestions on making my 87 IROC less noisey on rough pavement?-domain-pic.jpg
Old Dec 31, 2003 | 01:57 PM
xxxman's Avatar
Car: 1987 IROC Z-28
Engine: 350 5.7
Tires
I have Kumho ecstas. They are ok noise comes when I hit bumps. Is it the fact that IROC's have tight suspension?
Old Dec 31, 2003 | 02:18 PM
MilehighBird's Avatar
Car: 1987 Firebird Formula
Engine: 305 LG4
I'll second the subframe connector advice ,killed alot of creaking and rattles I had in my car.This winter I'm gonna replace all the front suspension with moog pieces and do the springs(moog) and shocks and struts(kyb)that might help also.You might want to think about new weather stripping and maybe consider using some sound deadening stuff in your doors(dynamat) .
Old Jan 1, 2004 | 07:09 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If noise is coming from the doors, you might check the following thread:
https://www.thirdgen.org/techbb2/sho...hreadid=124084
JamesC
Old Jan 1, 2004 | 04:07 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Subfames, maybe new door weatherstripping, and the door hinge kit from AndyZ28. Irocs will ride stiff so some of it you'll have to live with.
Ed
Old Jan 2, 2004 | 06:24 PM
xxxman's Avatar
Car: 1987 IROC Z-28
Engine: 350 5.7
That was a great thread. Lot's of great ideas...You are the man.
Old Jan 2, 2004 | 06:28 PM
xxxman's Avatar
Car: 1987 IROC Z-28
Engine: 350 5.7
Rear Hatch
All good ideas. What about the rear hatch? Just put in a new motor but it seems the hatch still sit's a bit too high and seems to be a source of some of the noise as the hatch bumps a bit on rough pavement.
Old Jan 7, 2004 | 02:17 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
May I suggest a really load exhaust system to drown out the other noises? I have edelbrock headers, no cats,3" mandrel bent Flowmaster system( cant remeber what series muffler,50 I think), and the carpet and insulation out of the back hatch area( due to an gallon jug of paint spilling in the back) and I cant hear a damn thing but the pipes! Or maybe a loud stereo?
Old Jan 9, 2004 | 09:30 PM
TransAmman87's Avatar
Car: 90 Trans Am
Before you go spending tones of money are SFC's, tires, shocks; consider this. I have a 87 T/A with almost hundred thousand miles on it. I took much of the plastic pieces off the car and put foam stripping (from the local fabric shop) on the edges and put the panels (all interior) and such back on. It didn't take long at all and it worked extermely well. When I go over rough pavement, the annoying sounds stop. Maybe you should try it.
Old Jan 15, 2004 | 11:54 AM
xxxman's Avatar
Car: 1987 IROC Z-28
Engine: 350 5.7
Hey sounds worth it. I think I will give it a shot.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Bradsaundry
Aug 12, 2015 12:34 AM
mustangman65_79
Aug 11, 2015 03:17 PM
