how do I loosen bolts for TDS wonderbar?
Old Dec 30, 2003 | 11:05 PM
matt formula's Avatar
Car: 1990 firebird formula
Engine: V8 305 TBI
Transmission: TH700R4
I just got the wonderbar steering brace from Top Down Solutions and when I went to install it I coundn't get the freakin bolts loose to bolt the thing in. Can anyone give me some tips on how to loosen those bolts.
Old Dec 30, 2003 | 11:29 PM
joshwilson3's Avatar
Old Dec 31, 2003 | 12:34 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
If you can find it, KROIL is about the best to use. I prefer the aerosol can (aka AEROKROIL). Spray the bolts from above as well as below. Let it sit overnight, then spray again. An air operated impact wrench works great. If you don't have one, then get a manual impact driver. The shock of hitting the end of the impact driver with a hammer will help to free up the bolt. Don't just use a cheater bar. You'll have a much better chance of snapping it off if you go that route.
Good luck,
Lon
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
snakeshooter
Sep 10, 2015 07:46 AM
Jlanz55
Sep 6, 2015 07:28 PM
TBRays98
Sep 6, 2015 05:05 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
