Best Torque Arm
Old Jan 6, 2004 | 12:26 PM
mike graycar's Avatar
Car: 88 iroc x 2- 1 T-Top, 1 Vert
Engine: 350 tpi, 305 tpi
Transmission: 700R4-2800 stall, 700R4 stock
Best Torque Arm
Allright, who makes the best torque arm. At a reasonable price that is. I did the searches, most threads degenerate into a discustion about what they are and how they work and who knows more. I want to hear from people who have them and why the like them and more importantly why the don't like specific ones they have used on their cars.-Mike
Old Jan 6, 2004 | 12:40 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Edelbrock makes one that is a considerable improvement over the stamped-steel stock version. See sig.
JamesC
Old Jan 6, 2004 | 02:00 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I have one of the first generation adjustable torque arms from Spohn. It really made a difference in how my car handled and improved traction quite a bit. As for why I chose it over the others: it was one of the first adjustables and it moved the arm off the tailshaft and relocated it to the crossmember which is where it should have been in the first place. Plus at the time the price was good.
Old Jan 6, 2004 | 02:01 PM
ede's Avatar
ede
anything or damn near anything would be an improvement over the stamped stock one
Old Jan 6, 2004 | 02:07 PM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
Amen to that ede!
Old Jan 6, 2004 | 04:22 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
I have the Sphon torque arm to and bought it for exactly the same reasons Mongoose, well that and the rest of my suspension is Sphon.
Old Jan 7, 2004 | 12:32 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Spohn's products kept me from going into business making suspension components for 3rd gen cars. I was looking to offer the highest quality product at a reasonable price, but when I started researching my competition I couldn't find anything they did that I would do differently. I knew I wouldn't be able to grab any of their market share, whithout severly undercutting their prices, and that made the venture cost prohibitive. In my opinion they offer the best stuff around.
Old Jan 7, 2004 | 01:24 PM
Jukka's Avatar
Car: "My American Dream"
Engine: V8
Transmission: auto
I run a work shop or what ever it is in english, but I can tell by the look of those spohn stuff that they really know what they do. Looks like they got good men working for them and they choose right materials.
Old Jan 7, 2004 | 04:16 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
S&W race car makes A really nice unit, it moves the mount to the frame, via crossmember that attches to their subFrame Connectors 100% Bolt On, I would still Tack weld Areas esspically around the bolt area to stiffen more and to keep bolts from coming out or elongating the holes
S&W Race Cars
Old Jan 7, 2004 | 05:20 PM
MdFormula350's Avatar
spohn:
likes = mounts on frame and take torque arm off the tranny, adjustable, quality / looks great, driveshaft is welded onto the new crossmember; everything is heavy duty (bushings, joints,etc..
dislikes = none of course
Old Jan 7, 2004 | 07:35 PM
10.90streetcar's Avatar
This unit looks pretty good.
TA1
TA2
VIDEO CHIC
Old Jan 8, 2004 | 12:24 AM
10.90, is that the jegs torque arm?
Old Jan 8, 2004 | 01:46 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
BMR maybe?
Old Jan 8, 2004 | 08:22 AM
yeah its the BMR Torque Arm
requires welding to the frame, i do believe.
Old Jan 8, 2004 | 12:31 PM
laiky's Avatar
The BMR is a nice unit, especially for the price but i believe it is more of a drag only piece due to its shorter lenght and the fact the front mount doesn't look like it allows the rear to rotate without binding.
Old Jan 8, 2004 | 01:07 PM
At this point i am leaning towards the edelbrock. Jegs has it listed for $180. This is much less than any of the other trans mounted non-adjustable torque arms. Any body have this one? part #5280
Old Jan 8, 2004 | 02:14 PM
MdFormula350 is right . It is the BMR and does require welding.
laiky is right for the most part, But the front mounting point does allow for movement.
VIDEO CHIC
Old Jan 11, 2004 | 04:59 PM
Well now, I was reading high po-chevy and they did a 3rd gen. suspension. they also showed an Edelbrock torque arm that is adjustable. I called Edelbrock who told me it is not yet available but should retail for 282 bucks. This can't be right, can it? I opened my new car craft yesterday and there it is on the first page. anybody know who carries this?
Old Jan 12, 2004 | 04:13 PM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
i have had the jegster for 5 years and i will be getting another one next month...
Old Jan 12, 2004 | 06:01 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I have the 1st gen spohn rod end tq arm I love it. It was worth every bit of money. Hardest part was wrestling it into place course might help if you have more than a foot worth of room under the car and you don't try doing it all by yourself in the rain (I was in a big hurry to get it on).
Old Jan 18, 2004 | 11:31 AM
anybody else ??
Old Jan 18, 2004 | 03:53 PM
joshwilson3's Avatar
Old Jan 18, 2004 | 06:06 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
Same here, had mine scince 1998 with no real complaints.The only thing I could complain about is that it's not adjustable - BUT - I've yet to see someone with an adjustable Spohn arm perform like my simple Jegster unit.
My results: Best 60ft 1.476 on 26x11.5x16 ET Streets on stock GTA wheels at 3,550lbs with 3.08 gears and is consistantly in the 1.47-1.49 range.
Steve
Old Jan 18, 2004 | 10:16 PM
No, not yet anyway. I started a construction company instead. I think I'll leave cars a hobby for now. I am working on a book that will specifically target certain 3rd gen projects, but who knows if it will ever make publication?
Old Jan 26, 2004 | 11:00 AM
anybody else?
Old Jan 28, 2004 | 07:56 AM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
I checked summit for the Edelbrock adjustable torque arm PN#5282. They've got it listed for $145,but it's on back order.
Old Jan 28, 2004 | 09:49 AM
How can it be so cheap? it's less than their non-adjustable arm and half of what the next cheapest competitor is offering. I hope it's not a total piece of crap !!
Old Jan 28, 2004 | 11:18 AM
Engine: 383 SBC
Maybe their trying to move the inventory since it's a new model for this year?
http://www.edelbrock.com/automotive/...uspension.html
Old Jan 29, 2004 | 10:25 AM
All the big guys (summit, jegs, ect.) tell me this is already back ordered into march. guess i will have to wait.
Old Jan 29, 2004 | 11:08 AM
Engine: 383 SBC
I'd put in your order that way they can't raise the price on you. I think they let you stay on back order list for up to 3 months. (stupid 3 guage pod apillar that took forever to come out)
Old Feb 6, 2004 | 10:22 AM
Did you order me one? how do i pay you? or them or what now?
Old Feb 6, 2004 | 11:15 AM
Engine: 383 SBC
Are you talking to me? I didn't order anything. I was just stating it might be a good idea for you to order it now from Summit Racing that way you're on file and you should get the lower price incase this is just a marketing scheme to get the new products out to people and start the word of mouth advertisements.
Old Feb 6, 2004 | 11:27 AM
OOPS! I misread your post, (hangover) I thought it said " I'll order" not "I'd order". I think I'm gonna wait. the edel. adjustable arm that was featured in the recent hi-po chevy magizine looks like a hefty piece. the one shown on the edel. website looks cheesey and kinda weak.
Old Mar 3, 2004 | 12:04 PM
anybody got the new edelbrock arm yet?
Old Mar 3, 2004 | 12:21 PM
GTA-SPD's Avatar
Car: 94 Corvette
Engine: LT-1
Transmission: Freakin Automatic---For Now
The arm in the Chevy High Performance article and the one on the Edelbrock website are the same arm. Edelbrock only makes 2, non-adjustable and adjustable. If it were my money, I'd look for one that takes the mount off the tranny, like the spohn unit. The other way you could go is with a MAC or Jegster one that are shorter than stock for better bite. I've been quite happy with Edelbrock stuff in the pst, and can't imagine that their adjustable arm would be any weaker than their non-adjustable, since they probably just cut up a non-adjustable and added some rod ends. I tend to think that ANYTHING would be an improvement over stock though.
Old Mar 3, 2004 | 01:01 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i've got nothing but good things to say about the spohn torque arm. my dad is running it on his and the car hooks so much better now. we had also ran the jegster one on his car years back and the suspension was binding bad, even going down the road on the trailer. the first weekend we had the car out with the new suspension and there was stuff all over the trailer floor that had gotten knocked loose cause the suspension could move again.
Old Mar 3, 2004 | 09:36 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
BMR makes some nasty products. my whole suspension is BMR and im actually ordering the BMR cromo TQ arm next week. the weld on kit they were talking about above is the trackpac and can be used on the street. but it makes a lot more road noise. from what i hear, it hooks up real nice though. can never go wrong with a BMR product...
Old Mar 4, 2004 | 12:10 AM
3ZZZ's Avatar
DOes the spohn make a loud clank when hard accelerating?
I am interested in getting ta after my conversion is done.
Old Mar 4, 2004 | 07:28 PM
Kontrax's Avatar
Car: 86 Camaro
i have heard about this noise myself and have asked many times and got no stright answer. i love my BMR anyhow
Old Mar 4, 2004 | 07:38 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
I've got my order in for the Edelbrock piece. I just got their adjustable panhard bar that is new for this year also. Both the adjustable torque arn and panhard bar cost 281.00 to my door. The torque arm is said to be delivered 4/4/4. I ordered them from Summit..
Old Mar 4, 2004 | 07:42 PM
91Z28-350's Avatar
The TA mounts to the x-member with a compression fitting. The bolt is narrower than the bushing opening (diameter). If the upper bolt is not tightened down with alot of torque compressing the fitting against the bushing, there will be thumping noise coming up near the shifter. The only problem is that it is a tight fit up there and getting some good torque on it is a bit tough, but still doable. It's best to put some loctite on it, but I didn't do that and may need to retighten the bolts in a few months.
Old Mar 4, 2004 | 08:53 PM
  #42
Kontrax's Avatar
Car: 86 Camaro
i saw the edlebrock arm with the rest of their stuff, in super chevy. they threw it all on a RS i believe it was a 92. they gave it great reviews, but i wasnt impressed with the unit. their stuff looks smaller and less ridged then other companies makes. i get all over kill because i have no idea what else im going to put into my car. already have the blower and getting that ready....even thinking about using a little juice too.
Old Mar 4, 2004 | 10:37 PM
  #43
EvilCartman's Avatar
Car: '82 Z28
Taken the other night... yeah it's a bit messy under there lol. Spohn torque arm and TH400 swap crossmember. No funky noises or clunks. Oh, and the exhaust doesn't hit the driveshaft when on the ground
Old Mar 4, 2004 | 10:59 PM
  #44
james_85Z28's Avatar
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
The locnuts (K-locs??) on the from TA mounts will not be effective after being installed/removed a couple times and will make a "thump" noise during shifts or bumps thereafter because they can't retain their clamp-up. Just replace them if this is occuring.
Old Mar 19, 2004 | 12:00 PM
  #45
Anybody got the Edelbrock yet? I see some guy is selling them on ebay allready.
Old Mar 19, 2004 | 11:11 PM
  #46
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
is the jegster ta geared more towards drag racing since its shorter? how does the length effect the geometry/benefits gained from the torque arm in drag and road applications?
Old Mar 20, 2004 | 08:46 PM
  #47
LO3Jeff's Avatar
Car: 1992 Camaro RS
Engine: (LO3) 305 TBI
Transmission: 4spd
add one more vote for spohn from me. I found them easy to intall if you have the rite equipment just like any job.
Old Mar 21, 2004 | 07:36 PM
  #48
giff's Avatar
Car: 91 G92 Formula, 35k original miles and owner
Transmission: 5 speed
Torque arm upgrade
Ok, here's a dumb question...
most of the posts I've seen only talk about how much more traction you get with an aftermarket torque arm, but what do they do for handling? i'm not interested in more traction just improving the handling on my car.
just boxed in my factory track bar and can definately feel a diff. Now looking at the track bar, but only if it will help handling. Not concerned with breaking the back loose when corning so if that's all that a torque arm upgrade will do - i'm not interested.
Giffman
Spohn SFC's, BMR STB. IROC wonderbar, boxed in factory track bar...poly bushings next...
Old Mar 22, 2004 | 09:40 AM
  #49
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Re: Torque arm upgrade
Giffman
Ok I am building my car for Street Duty. depending on the Torque arm, I am going to go with a adjustable One for several reasons.
One It moves the front mount point to the floor off the tranny so the will be less stress on the tranny and drive train, 2. it is adjustable so i can change the IC (instant Center) which will change the bite or center of gravity for more Bite on the rear.
I am not really sure of cornering benifits since I haven't done it yet but I am sure there are some, just keep asking around..
Just my .02
Old Mar 22, 2004 | 10:38 AM
  #50
GTA-SPD's Avatar
Car: 94 Corvette
Engine: LT-1
The short answer to the question is, yes the torque arm will help handling. Rear tire bite is as important to handling as it is to drag racing. You want the tires to plant when you start accelerating out of a turn, if they don’t you spin out. The better the rear of your car bites, the sooner and harder you can begin accelerating out of a corner. The aftermarket torque arms will help in all aspects of handling, I’ve even heard that they help with braking. I don’t know about that though.
