Replacing Upper Strut Mounts
Old Jan 12, 2004 | 11:54 PM
firewrks's Avatar
Is this procedure ok to replace the upper strut mounts?
To replace Upper
-Jack wheel just off the ground with a floor jack under front lower control arm.
-Remove Strut to Upper Mount Cover and Nut.
-Remove Upper Strut Mount to Wheel house tower nuts.
-Replace Upper Strut mount and tighten upper mount to wheel house tower nuts to 20 ft-lbs.
-Tighten Strut to Upper Mount nut to 50 ft-lbs.
-Get car realigned
Edit:
Also Does anyone know the manufacturer of the Upper Strut Mount Package sold at Spohn's site?
Old Jan 13, 2004 | 12:55 AM
MdFormula350's Avatar
not sure on the torque numbers dont have my book in front of me.
but the order u wrote down is the way i would do it.
Old Jan 13, 2004 | 11:05 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Be aware of possible problems. Check the following link:
https://www.thirdgen.org/techbb2/sho...hreadid=183622
JamesC
Old Jan 13, 2004 | 11:22 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That will not work.
Step 1 should be:
If you do it as you posted, the remaining force of the spring with the strut fully extended will still be trying to push the top of the strut the rest of the way out of the mount.
Old Jan 13, 2004 | 02:07 PM
vjo90RS8's Avatar
Car: 2002 Z28
Moog makes those strut mounts, should be DIRECT replacement for 87-92.
Old Jan 13, 2004 | 10:08 PM
yeah i was thinking about when i was doing springs, struts and i had everything apart.
stands under the a-arms with the rims off would be the better way.
Old Jan 14, 2004 | 11:21 AM
firewrks's Avatar
Thanks, I added "Jack wheel just off the ground with a floor jack under front lower control arm." to step 1.
Its an '87 Firebird so there should be no problem with the alignment of the Strut-Mount-to-Wheel-House-Tower nuts as stated in the other threads, correct?
Old Jan 14, 2004 | 01:09 PM
Jukka's Avatar
Car: "My American Dream"
Engine: V8
Transmission: auto
is it possible to change only upper strut bearings? One would not have to change entire upper strut mounts. Anohow, do you know? I have all the machinery in the world to do that so proper tools are not issue. only thing might be that if the strut mount damages when the bearing is removed
Old Jan 14, 2004 | 02:26 PM
vjo90RS8's Avatar
Car: 2002 Z28
the bearing is non serviceable
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
TheExaminer
Aug 25, 2015 07:34 PM
wruiz
Aug 11, 2015 02:59 PM
