e-brake not working
Old Jan 17, 2004 | 05:17 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
e-brake not working
You pull it back and nothing happens, it will just go all the way back (vertical). To get it it work you need to hold the silver tab (don't know what its called) up. The problem is it isn't catching the teeth, it used to work if you pulled it to the passenger side as you pulled it up. The teeth don't look worn which is what gets me.
Anyone have any idea whats up, would I be better off just getting another e-brake, it looks like its just 2 bolts and the cable to change it but I havn't looked hard.
Old Jan 23, 2004 | 05:52 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Any ideas?
Old Jan 24, 2004 | 09:42 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Sounds like it just needs adjustment. You can make adjustments to the travel length by moving the tensioner which is under the car in the trans tunnel, looks like this:
Old Jan 24, 2004 | 09:48 AM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
I really don't think its the ajustment. If I pull that metal level up as I pull back the e-brake it works fine. But if I don't the handle just goes right back, and you can see how its not catching the teeth where it should be. Ill try ajusting it a little though and see if it helps.
Old Jan 24, 2004 | 01:22 PM
ebmiller88's Avatar
OK, I get it... I'd just get another e-brake lever and replace the one you've got. You should be able to get one from Roy (TGR) or Bruce (Hawk's) for less than $20 and it's a quick fix. If it fixes the problem, adjusting it won't be necessary.
Click their links at the top of the page.
Ed
Old Jan 24, 2004 | 02:31 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Thanks, thats what I thought I was going to have to do. I just asked incase there was some quick fix I didn't know about.
Thanks again.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
