93 T/A rear
Old Jan 20, 2004 | 11:28 AM
Formula4Speed's Avatar
Car: 1990 Formula
Engine: 305 TBI (LO3)
Transmission: 5 speed manual
93 T/A rear
Someone local to me is selling the rear from a 93 T/A its posi with brakes (not sure of gear ratio i'm hoping 3.23). Anyway if I do swap that in I assume I would have to upgrade my front brakes as well, correct? This is probably a dumb question but I really don't know anything about brake systems :lala:
Old Jan 20, 2004 | 11:44 AM
ede's Avatar
ede
you don't have to do anything to the front brakes
Old Jan 20, 2004 | 03:32 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
93 is the funky year for the rear ends since the 6 speed cars got either the 2.73 or 3.23 geared rears.
Auto has the same ratios too I believe.
94+, all the 6 speed cars came with 3.42 geared rears.
Old Jan 20, 2004 | 06:44 PM
Car: 1990 Formula
Is there an easy way to tell? (Keep in mind I know nothing) And what is a good price for a full rear assuming its in good shape? He wants $350 obo...I haven't had time to check out and junk yards yet...
Old Jan 20, 2004 | 07:08 PM
Zepher's Avatar
Good price for a complete disc rear end is $200-450, depending on the rear gears and brakes, LS1 rear & brakes are desireable.
I guess the easiest way is to put a mark on the axle flange and turn the pinion around x amount of times till the mark on the flange returns to the start position. A little more than 3 rotations of the pinion will be 3.23 and a little less will be 2.73.
We did this test on a 4.10 rear I have sitting around and the pinion turned 4 times to the 1 rotation of the axle flange.
Old Jan 21, 2004 | 04:03 AM
Frains90RS's Avatar
Car: 1990 Camaro RS
Engine: LO3: 305 TBI
Axle/Gears: 1997 Trans Am rear w/ posi -3.23
I lucked out.
I paid $400 for a complete 95Z rear with posi and 3.23 gears, and a 99 T/A alum. driveshaft. Look around locally and try to avoid getting it shipped.
Good luck, Efrain.
Frozer!!!
Jan 19, 2024 04:55 PM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
IMissMy86TA
Aug 31, 2015 08:40 PM
Akinnepa
Convertibles
Aug 26, 2015 10:54 AM
