Control Arm Bolts
Old Feb 4, 2004 | 07:28 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
Control Arm Bolts
Trying to get the rear control arm to body bolt. would heating do any good since its rusted on the inside of the bushing? I'm talking stuck a brand new Ingersol Rand 232TGSL impact gun wouldnt even budge it.
Old Feb 4, 2004 | 07:45 PM
ede's Avatar
ede
screw a nut on it to protect the threads and try a BFH
Old Feb 4, 2004 | 11:33 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
didnt budge it
Old Feb 4, 2004 | 11:34 PM
bes217's Avatar
SAWZALL!!!!!
Old Feb 5, 2004 | 12:01 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
thats next on the list
Chunster's Avatar
Car: 1985 IROC-Z
Engine: 5.0L TPI
Transmission: TH700R4
You could also use a grinder or a dremel (would take a little while) to take off the bolt or head of the nut. Also a little penetrating oil and letting it sit overnite may solve your problem as well.
Old Feb 5, 2004 | 05:15 AM
ede's Avatar
ede
i'd try heat next or a Co2 extinguisher
Old Feb 5, 2004 | 08:22 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Trash it and then replace it with a new one. TomP posted a whole list of new bolts for suspensions a while back, the part numbers are all there.
Ed
Old Feb 5, 2004 | 11:11 AM
Brett H. - 89GTA's Avatar
Car: 1989 GTA
Engine: 5.7L
Axle/Gears: 3.27 BW 9-bolt
I had to cut mine out with a Sawzall too. It takes awhile...the bolts and sleeves are very hard. Use good bi-metal blades and a lubricant while you're cutting to save the blades. You will probably go through a few of them.
Old Feb 7, 2004 | 07:33 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Should you decide on new bolts, you might consider those in the following link:
http://www.spohn.net/category.cfm?categoryid=1032
JamesC
Old Feb 7, 2004 | 10:38 AM
JamesC's Avatar
JamesC
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
anesthes
42
Oct 24, 2015 07:30 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
