Jegster roll bar
Old Feb 12, 2004 | 12:44 AM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
Jegster roll bar
I just purchased a jegster 4 pt. roll bar and the directions are not very informative. Where exactly are you to place the legs of the bars? You are supposted to weld the bottom of the bars to the supplied plates but the way the floor plan sits the plates don't sit flat. Do you have to put a solid piece of steel under the unsupported part?
Old Feb 12, 2004 | 05:52 AM
ede's Avatar
ede
you should check the rules where ever you intend to compete. nhra reqires 11gax6x6 plate with the tube welded to it and the plate welded to the floor. i'd cut the plate larger and mitter the tube to fit the plate at whatever angle it needed it be at.
Old Feb 12, 2004 | 03:12 PM
subsonic9's Avatar
Car: 86 IROC
Transmission: WC T5
I put mine on the junction just behind where the door opening is. It was a major pain in the a$$, Had to bend the plates to form to the area. I wish I had pics. The interior is back in(carpet). It did work. Three days of work. Oh mine was the 8 Point. I forgot, I had to bend the upright bars a little to make it work. Good Luck
Old Feb 12, 2004 | 07:51 PM
Thanks for the info guys. At least I am making it a 2 seater. I also am not competing in it so the cage is mostly for my personal protection and chasis stiffness. I also love the look.
Subsonic....did you just head weld the plate to the floor panel? Don't you have to weld it to the frame?
Old Feb 12, 2004 | 07:59 PM
subsonic9's Avatar
Car: 86 IROC
Transmission: WC T5
I will take pictures tomorrow and explain what I did. It is hard to explain without the pics.
Old Feb 13, 2004 | 12:37 AM
Thank you soooo much....you will be a savior
Old Feb 13, 2004 | 07:19 AM
ede's Avatar
ede
weld the plate to the floor pan, there is no frame. could be welded to SFCs but it's take a bit of work since the two parts aren't in the same place, and sort of pointless.
Old Feb 14, 2004 | 12:24 AM
Is that safe enough?
Old Feb 14, 2004 | 07:24 AM
ede's Avatar
ede
all nhra requires is a 6x6xc.125 plate at the end of the tube welded to the floor pan. i'd think they've put some time and thought into it and the safety aspects of the installation.
Old Feb 15, 2004 | 12:30 AM
mabee just a little
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
FormulaEngland
Sep 30, 2015 01:50 PM
