Installing Comp. Engineering Bolt On SFC's
Old Feb 26, 2004 | 07:15 AM
KZad's Avatar
Car: 88 Formula, 04 CTS-V, 06 Commander
Engine: 305 TBI, LS6, 4.7 V-8
Transmission: 5 spd, B&M Short Throw
As the subject says I'm going to be installing Competition Engineering's Bolt On SFC's tomorrow, but I have a quick question.
The directions say to jack the car up in the air and to rest it onto four jack stands by the frame, and let the rear hang down - but supported by a jack.
Does this make any sense to anyone? I always thought that to put on subframes, you'd want the car to sit in the position that it normally drives in, ie jack it up and support it by the wheels or axle.
I guess I'll still follow the instructions because that's exactly what they are .... instructions, but does anyone have any thoughts about this?
thanks,
KZad
Old Mar 3, 2004 | 09:08 PM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
i have the same subframe connectors and i was wonderign the same things... havent installe dthem yet... im gonna powdercoat them first...
Old Mar 3, 2004 | 09:49 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
yeah, jack the car up and support it by the rear axle so when you unbolt the trailing arms, the rear dont fall out you also need to support the rear of the body itself. i used stands on the body and a 3 1/2 ton floor jack for the rear under the diff. i dont see why you would want the car at its ride hight because your just popping in some extra frame...its not like installing new arms or nothing like that. you really gonna bolt those in or you gonna weld em when you get the chance?
Old Mar 3, 2004 | 11:13 PM
HamSpiced's Avatar
im bolting mine in first, then tacking it in... im waiting till i get a hookup on a lift, then ill re-weld it all...
i need to get it in before i get my exhaust....
Old Mar 8, 2004 | 08:01 AM
KZad's Avatar
Here's a link to some of the pics I took during my install. Its just a few, I need to upload the rest.
Installation went pretty smoothly.
http://community.webshots.com/user/KZad88
Old Mar 8, 2004 | 03:52 PM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
how do u like em, and how much are they
Old Mar 8, 2004 | 04:08 PM
HamSpiced's Avatar
notice much of a difference?
Old Mar 9, 2004 | 07:59 AM
KZad's Avatar
[Do you like em and how much are they]
Yes I like them. I went through a whole ordeal trying to get them. First I bought CE weld in SFC's for 115. Exchanged them (minus 20% restocking fee) and paid an extra 75 for the bolt on's. So figure I paid 160-170 for them.
[notice much of a difference?]
Yes, a very noticable difference. The car is stiffer all around, and I really noticed it yesterday when I went (Diagnal) over a speed bump. Very nice improvement, almost like the whole driver's side lifted with the front wheel. Hard to explain.
Its hard for me to attribute what gains were from what, because while installing the subframes, I also put on Spohn's wonderbar, and LCA's.
Hope that helps.
(I put more pics up yesterday. Mostly pre-installation pics to compare to the finished job.)
Old Mar 9, 2004 | 11:24 AM
HamSpiced's Avatar
im putting the SFC's on too.. same ones.... but im also putting on a Hotchkis(sp?) STB with it... so again.. ill see a difference, but i wont know how much are just from the SFC
Old Mar 9, 2004 | 03:37 PM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
were these the sfc's that needed to modify ur floorboards? i was thinking about geting the jegsters bolt ons. r these better.
Old Mar 9, 2004 | 03:54 PM
HamSpiced's Avatar
as was already stated... the floor boards dont need to be modified except for drilling maybe a hoel or two for the bolts....
Old Mar 9, 2004 | 04:27 PM
KZad's Avatar
HamSpiced -
You will notice a world of difference doing both the SFC's and the Strut Tower Brace. I've had a strut tower brace on my car for about a year now, and notice a big difference when I put it on.
TKD-
The CE Weld_On SFC's you need to modify your floor pan. For the bolt on's you need only drill about a dozen 13/32" holes to mount the frames up. these holes are drilled both through the floor pan running along the door sil, and also into the frame itself. Not a big deal at all.
I don't know anything about the Jegsters.
Old Mar 9, 2004 | 06:16 PM
Kontrax's Avatar
Car: 86 Camaro
youll notice the subs right away when you punch it. the car launches better and corners better at high speeds. the brace makes the car corner better too. couldnt really notice either of the 2 unless i was going 40+ but the launch youll notice right off. it basicly comes down to better highway driving
Old Mar 9, 2004 | 07:21 PM
HamSpiced's Avatar
im sure ill notice when i go off the curb backing outta my drive like i always doo (neighbors love me!!!)
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
