Rear PBR Upgrade???`
Old Apr 2, 2004 | 04:06 PM
CamMan83's Avatar
Car: 2001 VW Passat
Engine: 1.8 Turbo
Transmission: Automatic 5 speed with Tiptronic
Axle/Gears: Stock
I have an 87 Borg-Warner rear with disc brakes and they are the standard option. Can I just purchase the PBR rear brakes at Advance (they do carry them) and bolt them on without any mods? Thanks
Old Apr 2, 2004 | 05:12 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Depends what you mean by bolt-on... if you also replace the pads, rotors, caliper mounting hardware, caliper brackets, brake hoses, parking brake cables and backing plates, then yes you can bolt the calipers on without any mods.
Old Apr 2, 2004 | 10:41 PM
CamMan83's Avatar
Car: 2001 VW Passat
Engine: 1.8 Turbo
Axle/Gears: Stock
So to switch it over, I have to buy everything then? I can't just buy the caliper and bolt it on, are the rotors bigger too? and why would the mounting have to change?
Old Apr 2, 2004 | 11:42 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There is nothing remotely similar between the cast iron Delco Moraine calipers and the aluminum PBRs.
Old Apr 3, 2004 | 06:11 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Here's a thread, which includes a pic, that may help:
https://www.thirdgen.org/techbb2/sho...rear+brake+kit
Another Kansan, huh, cool! By the way, I'm in the process of swapping to PBR's. If I can be of any help, let me know.
JamesC
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
