Spohn LCA's and SFC's installation question.
Guys:
I was wondering if anyone has any pics of where the Spohn SFC's weld in at the rear.
I am getting confused as to which should be installed first:- The SFC's or the LCA's and LCA relocation brackets
Thanks.
Thanks.
Transmission: 4L80E/4L80E
The rear of the subframe connectors bolt on to the front LCA mount.
So, either pull that bolt twice, or do them at the same time.
Personally, I'd do the SFC's first.
Agreed, you might as well do them at the same time. You have to drop one side of the LCA to install the SFCs. So when you put up the SFCs, you hold them up in the rear by the LCA bolt and find a good place to weld from there. Sorry I don't have the pic, as I'm at work.
i'd do sfc's first then install the new lca's and then do the brackets.
https://www.thirdgen.org/techbb2/sho...ation+brackets
1992rs/ss
Jan 31, 2025 05:10 PM
ambainb
Apr 25, 2016 09:21 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
NBrehm
Aug 5, 2015 07:57 PM
