Drum to disc ???
Old Apr 9, 2004 | 12:44 AM
irocet305's Avatar
Car: 91 Z28
Engine: L98 350
Transmission: Tire Chirpin A4
Drum to disc ???
I sawpped my drum rear out of my 91 Z28 for a rebuilt 88 J65 disc rear. I did the recall on the calipers, and still have little holding power on the brakes, and the pedal goes 3/4 of the way to the floor before they grab....
Car has all new:
lines
pads
rotors resurfaced
solo bleeds
system bled with 16 oz of fluid thry gravity and 16 oz mity vac bled.
Is there a difference in the booster, propotioning valve, or master cylinder between the drums and disc's? Maybe this might be my problem
I did a search and low and behold all of the things that guys are saying to be potential things to look for have been done. Maybe if there is no difference in the booster, propotioning valve, or master cylinder just try to bench bleed the old master then? I would like to not replace everything from the master cylinder all the way to the calipers....even though I am half way there.
And another question. When you bench bleed the master cylinder how do you keep fluid from going everywhere when installing it?
Old Apr 9, 2004 | 08:07 AM
CamaroMike's Avatar
Adjustable prop. valve is an absolute must!
Old Apr 9, 2004 | 09:47 AM
irocet305's Avatar
Car: 91 Z28
Engine: L98 350
That seems like a band aid fix at the moment though. I still won't have the firm positive pedal feel after that, though the brakes might grab better in the rear.
Old Apr 10, 2004 | 10:31 PM
CamaroMike's Avatar
The drum combination valve holds off the front brakes until the shoes have overcome spring pressure! If you switch to discs in the rear then there might not even be enough volume to drive the discs effectively. This would hold off the front brakes untill fluid pressure built up.
YOU ABSOLUTELY MUST GET RID OF THE DRUM COMBINATION VALVE AND GO TO AT LEAST A FACTORY REAR DISC PROP VALVE, EVEN BETTER AN ADJUSTABLE PROP VALVE!
Old Apr 10, 2004 | 11:02 PM
irocet305's Avatar
Car: 91 Z28
Engine: L98 350
The guy I bought the rear end from has the correct prop. valve he's giving me. I'll install it and let cha know how it turns out....
Old Apr 11, 2004 | 12:24 AM
Droptop_Z's Avatar
Car: 88z
Transmission: t-5
I switch my drum rear to a disc rear a few months ago. The year of the camaro that I got the rear out of was a 1990, but I think the rear came from a diffrent year. My question is does the year of the prop valve have to be the same year as the rear end, or are they a one size fits all set up?
Old Apr 11, 2004 | 06:31 PM
CamaroMike's Avatar
Matching the year of the rear to the Prop valve is the best way to get factory performance. I would personally just install an adj. valve and be done with the brakes. Nice thing about the adj. prop valve is that as you upgrade your suspension you can change your braking characteristics to match your needs.
Old Apr 11, 2004 | 09:08 PM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
i'm switching my 88 drum rear for an 89 pbr disc rear this summer. what prop. valve will i need to avoid this problem in the future? The original one isn't available so where can i buy teh adjustable one? or should i just stick to finding one from a car with pbr rear?
Old Apr 12, 2004 | 08:10 AM
CamaroMike's Avatar
Bear Brakes or Willwood sells an adj. prop valve. Try Summitt for Willwood and the Bear website for their valve.
Old Apr 12, 2004 | 08:37 AM
nikh23's Avatar
ah found em, are these prop valves direct replacements to the stock pieces or does something else have to be done to muont them properly? Does anybody have pictures of how they've moutned theirs in the car?
Old Apr 12, 2004 | 09:49 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
theres a short tech artical about it here:
https://www.thirdgen.org/newdesign/tech/propvalve.shtml
i just wish someone made bubble flare to double flare adapters
Old Apr 12, 2004 | 10:27 AM
CamaroMike's Avatar
Their are metric to standard and vise versa brake line adaptors at your local auto parts store. When I mounted my adj. prop valve I threw out my factory combo valve and replaced everything from the master cylinder to the factory brake lines with standard stuff. Meaning that I left the metric brake lines (on the subframe and rear axle housing) in place and adapted the standard stuff to the metric lines. I just used metric to standard adaptors on the master cyl. and standard to metric adaptors on the factory front brake lines. The front factory brake lines are tricky though because you have to use a double metric female with a metric male to standard female. The only catch with the rear is that you have to plumb the system all the way to the rear hose with standard stuff then you can adapt into the metric hose using a standard female to metric male. Also, the rear brake line diameter must be changed to a smaller diameter (3/16" I believe) but that is ok because the hole in the rear brake line is smaller than 3/16" even though the factory brake line is like 1/4" or so, go figure.
Old Apr 12, 2004 | 02:18 PM
nikh23's Avatar
i'm an idiot. for as long as i've been on this site you'd figure i'd know about this already. sorry about that guys and thanks for the heads up mrdude
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
jrdturbo
Mar 31, 2016 02:58 PM
92projectcamaro
Dec 8, 2015 12:25 AM
KO1
16
Oct 15, 2015 05:00 PM
indygene
Sep 26, 2015 11:21 AM
