BMR Trak Pak Torque arm install
Old Apr 14, 2004 | 07:52 PM
OhioIroc's Avatar
Car: 86 Iroc
Engine: 305TPI
I ordered a BMR Trak Pak Torque arm to help with traction. I also need some Subframe connectors? I don't know which ones will work out the best because that torque arm crossmember needs to be welded on to a SFC. I was wondering if any of the members here are using the trak pak torque arm from BMR? And If so what all did you do for the install? Any info would help Thanks in advance
Tony
Old Apr 19, 2004 | 11:01 AM
OhioIroc's Avatar
Car: 86 Iroc
Engine: 305TPI
come on guys I know at least one of you have the trak pack torque arm!
Old Apr 19, 2004 | 12:35 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I had the BMR for a short time. yes, you need to weld the crossbar to cub frame connectors. That crossarm hangs so low though because of the "droop" area that it dragged on everything.
I soon removed it and bought the spohn tq arm. I would reccommend you do the same before you weld it in, see if you can return it.
Old Apr 20, 2004 | 08:26 PM
OhioIroc's Avatar
Car: 86 Iroc
Engine: 305TPI
Thanks for the input Do you like the sphon was it easier to install
Old Apr 21, 2004 | 01:10 AM
Engine: 4.0L
The Spohn tq arm was very easy to install.
http://www.spohn.net/category.cfm?categoryid=1047
Old Apr 27, 2004 | 06:23 PM
OhioIroc's Avatar
Car: 86 Iroc
Engine: 305TPI
The spohn torque arm mounts to the tranny right? I don't want a arm that mounts to the tranny. I think I might still go with the bmr track pack I here a lot of positives about the great traction of this unit.
Old May 1, 2004 | 01:37 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
i used SSM SFC with the BMR TRAK PAK. they are square not round SFC. http://www.fl-thirdgen.org/mrr23/mrr23-17.html
Old May 2, 2004 | 07:12 AM
Engine: 4.0L
No, the Spohn tq arm does NOT mount to the tranny. It mounts to a brand new crossmember included with the kit. You throw your old crossmember out or give it away.
Old May 2, 2004 | 08:22 PM
OhioIroc's Avatar
Car: 86 Iroc
Engine: 305TPI
its a tough call but I already have the bmr track pack in my garage so I think I will buy some jegs boxed SFC's and start welding
Thanks a ton for all the info
Tony
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
