9.5" width up front?
Old Apr 15, 2004 | 09:24 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
My wife works at a service station that sells wheels and tires. I was flipping thru some wheel books that are there and I found a wheel that I've NEVER seen on ANYTHING before. It is a 5 spoke, somewhat rounded spokes, like the SS/ZR1 rims, but its more deep dish.
Anyway, The only sizes available are 18x and 20s. I want to get a set of the silver 18's although they are one width, 9.5".
My hope was for front to be 18x8ish and rear to be 18x9.5 but it doesnt look like thats possible with this wheel. I did some more checking and the warehouse is RIGHT IN TOWN.
I can get the set for cost of $211/per no shipping needed. ANYWAY, these rims are offset for a 3rdgen from what I found out... Will the 18x9.5" rim fit all 4 corners? Will it look funny being that wide up front? My wife told me she will let me buy them with our tax refund!
Got any pics of 9.5" wide rims on a car?
ALSO: What would be the max width of the tire?
Old Apr 16, 2004 | 09:13 AM
killsupraman's Avatar
9.5 inches wide should fit fine... Depending on the offset. I run 10" wide jong bloed wheels with 285 40 17 firehawks. No modifications needed. you may have to roll the fender, some cars are just a little bit different. With 9.5 inches wide I would run no more than 275. It is up to you though.
Old Apr 16, 2004 | 09:58 AM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Are you saying a 275 will fit without rubbing/modifications on an 18x9.5?
Old Apr 16, 2004 | 10:29 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Depending on the aspcet ratio it should. I run 17x9 up front with a 26" tall tire without any rubbing at all. I am also lowered quite a bit as well.
Old Apr 16, 2004 | 01:02 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
I plan on lowering, not much but basically for some appearance and mostly for handling. I want to run a smaller width up front but unfortunately the company doesnt offer it in anything but 18x9.5"
DOES ANYONE HAVE 9.5" wide rim pics on the car?
Old Apr 16, 2004 | 01:37 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Here is mine. You can see more pics in the links in my sig.
Old Apr 16, 2004 | 03:10 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Are you running spacers? The wheels Im looking at are supposedly offset for 3rdgens.
Old Apr 16, 2004 | 04:31 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
No spacers. My wheels to are specifically tailored for 3rd gens.
Old Apr 16, 2004 | 05:25 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Here is a pic of the wheel I am looking at. Apparently its a Ford Lightning knock-off:
Old Apr 16, 2004 | 05:51 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Problem: or is it?:
Patterns include:
5x5.5
5x135
5x5
Thats too big for a 3rdgen, correct? If so, DAMNIT!
Old Apr 16, 2004 | 11:27 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Anyone?
Old Apr 18, 2004 | 08:34 PM
Adrenaline's Avatar
Car: 92 Camaro RS
Yeah too big, camaros and most Chevy's are 5 X 4.75
Old Apr 18, 2004 | 09:21 PM
formul8!!'s Avatar
Car: 2004 GTO
I run 17x9.5" rims with 275/40/17 tires all around on my '89 Formula. They only rub a little on full lock at low parking lot speed.
Old Apr 19, 2004 | 02:49 AM
ronterry's Avatar
Car: '94 Corvette
Interesting, what back spacing are you guy running for the fronts with 9.5's.
I was going to try 10" I just want to be able to use the same tires on all four. Probably 295/50-15's
Ron
Old Apr 19, 2004 | 06:26 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
17x9.5's require a 5.5BS and you can run 275's in all 4 corners.
at leats TT2's require a 5.5BS to run 9.5's in all 4 with 275's
Old Apr 19, 2004 | 04:48 PM
ronterry's Avatar
Car: '94 Corvette
I thought it was pretty close with 5"BS. I test fitted one of my rear 10" with a 5"BS on the front, and doesn't hit any thing but I didn't try it lock to lock. It was also wheel only.
Ron
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Feb 13, 2016 10:04 PM
Horridbulldog
Wheels and Tires
Feb 13, 2016 07:22 AM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
