Front LCA bushing install
Old Apr 17, 2004 | 09:49 PM
Mavrick's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: 5 speed
So i got the front end kit from Spohn and still need to install the ball joints and lower control arm bushings. I'm gonna have the shop do the ball joints and was wondering if i should go ahead and just have them intstall the bushings as well. Are they really hard to get out, and then press back in? If its not to bad I'll do them myself.
Old Apr 17, 2004 | 09:57 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
you can do them your self. if you arent going to reuse the shells then i would just take a cold chisel and chisel the edges and then pound them out with a hammer. use the vise to put them back in. i did and it took me about 1 hour to do the four bushings on the two from control arms.
Old Apr 17, 2004 | 09:59 PM
BG87z's Avatar
Car: 1987 IROC-Z
Engine: Carbed 355
Transmission: TH-350
I've done a few front suspensions and they are all different. But most of the time its not that hard to get them out cause you can just beat the **** out out of it. Getting the new one in is always tough. If they don't charge much then just have them do it. It is definetly do-able at home though so it's up to you and if you do, be patient, it will work.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
TheExaminer
Aug 25, 2015 07:34 PM
wruiz
Aug 11, 2015 02:59 PM
NBrehm
Aug 5, 2015 07:57 PM
