strut replacement
Old Apr 27, 2004 | 01:06 PM
xpence's Avatar
strut replacement
What's the best way to break loose the lower mounting bolts.Do you have to remove the hub and use air tools? I hate bringing my car to the garage,but I don't have a compressor yet
thanx
Old Apr 27, 2004 | 03:40 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
i had to remove the rotor and use an impact, only took me 30 min aside, and you can check on your wheel bearings while you are at it.
Old Apr 28, 2004 | 08:51 AM
xpence's Avatar
thank you
Old Apr 28, 2004 | 09:49 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i left the rotor on..
did it all with handtools.... i donno what vic_V8 was doing in the mean time, but at a hurried pace with all the tools laid out, it took me about 20mins per side... (i was in a rush for a event that night)
my car is a 100% southern car without a speck of rust, so the nuts broke loose with a breaker bar without issue... just stick the jack under the a arm, and break em loose. i didnt need a impact at all..
i had the shocks and struts done in about a hour, all with hand tools in the driveway, however like i said, i didnt have any problems because i have a southern car... your miliage may vari.
Old Apr 28, 2004 | 09:51 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
vic_V8 : heh, re-reading that, i came off a lil rude... what i was trying to say was, with air tools, it shouldnt take very long at all.
once the wheels were off, you can zip all 4 nuts off in about 2 mins.
Old Apr 28, 2004 | 10:02 AM
xpence's Avatar
re
Unfortunately I have a N.H. car with 120,000 mi.It has never been driven in winter but there is a lot of rusty parts underneath.The struts look like the originals.I've tried a breaker bar on the top lower mounting bolt but no go.I haven't tried a breaker bar and a pipe yet.I'm thinking I'm going to need a compressor in the future to paint so I may go get one today.How big a tank do I need and how many psi to run impacts & spray gun
Old Apr 28, 2004 | 10:09 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I soaked mine for a couple of days with WD-40, then used a breaker bar (I can't recall if it was 18 or 24 inches). Bolts came off without difficulity.
JamesC
Old Apr 28, 2004 | 10:11 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Re: re
this is one of thoes cases where bigger really is better.
if you're planning on spraying anything id go with nothing lower then 20gal... athough with the price diff between the two, id probly buy a 35gal.
with the tiny UFO shaped 5gal one, you can probly get two of thoes bolts out before the compressor kicks in... but then you have to wait until it fills again before you can get the other 2.... better then nothing, but not worth the money IMO.
Old Apr 28, 2004 | 10:34 AM
xpence's Avatar
So you think 35gal will do both jobs O.K. Wow 35 gal. are some coin,I found a 24gal that runs on 120 5.7cfm@90 psi,how bout that.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
TheExaminer
Aug 25, 2015 07:34 PM
g.l.mos
Aug 22, 2015 12:02 AM
1992 Trans Am
Aug 9, 2015 04:32 PM
