Putting on Earl SS brake line?
Old May 6, 2004 | 05:06 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
MY Earls SS brake lines will be here tomorrow from Spohn's and I want to get a head start on things.
How do I take the old rubbers off? am I going to be reusing the line brackets that are attached to the rubber lines? (I have them marked) or will they not be used with the SS lines?
If there are going to be reused how do I get the lines off of them?
DO I undo the bolt that holds them on and then work on removing the lines?
Or do I just undo the bolt marked in red and then take all the rubber lines off with the brackets attached.
Sorry for the stupid questions!..
thanks!
Old May 6, 2004 | 05:21 PM
Jon92TA's Avatar
Car: 92 Trans Am - Sold
Yea the brackets get reused, not necessary to unbolt them. The clip you have circled is a PITA but pulls straight off.
Old May 6, 2004 | 05:39 PM
Ok I got them off...your right they are sorta a PITA......but I gottem out....now just waiting on the new lines..I dont wanna take the old off cause I'll lose all my fluid...and then end up with air in the MC.....
Old May 6, 2004 | 08:30 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Once disconnected plug the line so that the master doesn't drain - like put a rubber cap over it or whatever.
Get penetrating oil on the fittings first though . Once it's soaked use compressed air to blast the crud away so it don't get into the lines.
Use a 3/4 box (not 3/4 inch obviously but a proper line wrench) to loosen the bolts - two wrenches where needed. Once the fittings loosen a bit rock them back and forth to help free up the threads.
After it's loosened off but before disconnecting - give it another blast of air to get rid rust, crud etc.
I noticed quite a difference with these lines once installed.
Old May 6, 2004 | 08:39 PM
Thanks! I never thought about crap getting in when I lossen them up...Im going out right now to soak them with PO...so they come off easier tomorrow when I get the new lines...
Reddeath210
Oct 6, 2015 08:20 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
