slicks, sfc's, converter and a crappier 60'. wtf mate?
Old May 8, 2004 | 05:15 PM
berlinetta85383's Avatar
Car: 85 berlinetta
Engine: 383 stroker
last year I was running 1.9 sec 60 foot times and I had a pretty much stock suspension except for lakewood lca's and some stiff shocks. I was running 27 by 10inch (cascar slicks) soo anyways over the winter the car gets a 200lb diet, sfc's and a set of 28by12.5 mickey thompson et streets. The slicks are roughly the same width, beacause they are measured differently.I also got a new tranny with a true 2400 stall, and now the best time I have this year is a 1.96. The car is way more consistant now, but I was hoping for 1.8's atleast with these mods. I have 4.10 gears, It kinda seems like im bogging outta the hole.
Old May 9, 2004 | 02:53 PM
MdFormula350's Avatar
with slicks i would of thought way better than 1.8 60 foots and u didnt even get that. hmm does it seem like its spinning, like u said could be bogging for some reason; might need some better tuning.
did u mess around with tire pressure?
also slicks need a pretty good sized burnout.
Old May 13, 2004 | 06:16 PM
caribbean 85's Avatar
Car: 1985 Berlinetta (drag only)
Engine: 383ci chevy
Transmission: TH-350 T-brake
Axle/Gears: 9 inch Ford & 4.56 gears
Might want to double check state of tune
distributor advancing o.k.? set for all in by 3000 rpm?
it took me a long time to figure out my HEI began sticking up -
and I was having a poor set of runs
however I think the tyres may just be big and may need to a different launch sequence - more launch rpm and perhaps longer in 1st
the 4.1 and the low 1st gear 700r4 should be equal to the task, but you know our 1-2 shift loses some rpm
you could try and revert smaller slicks for comparison
hang in there!
Old Jun 11, 2004 | 05:45 PM
Car: 85 berlinetta
Engine: 383 stroker
well It was my old converter it was maybe flashing up to 2100 rpm... my accelerator pump was also shooting in a bit too much fuel off the launch. The actual 3200rpm stall I got livened things up alot and it now spins the slicks a fair amount. I think some of this will be cleared up when I put my battery in the back. Thanks for the help once again gang!
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
BOOT77
Sep 16, 2015 08:37 PM
gta892000
Sep 16, 2015 12:37 AM
DARKmj16
Sep 9, 2015 04:07 PM
