What Brand Torq Arm??
Old May 8, 2004 | 11:57 PM
OneBadZ4U's Avatar
Car: '86 Iroc, '87 Iroc Vert
Engine: 350 TPI, 305 TPI
Transmission: T5 in both
Axle/Gears: 3.73, 3.45 both LSD's
Hey guys, this is my first thread started. I searched archives and couldn't find my answer. Tonight I twisted my torq arm. It basically happened like this: I was driving with my wife when we came along a car driving slow and looking like he was turning left. I went to pass the guy on the right and he turned into my car. He dented my driver side door. I pulled forward to stop and he continued to turn and drove off. I put the car in reverse, hit the gas and Pa-dow. I guess I hit the gas to hard?? Anyway couldn't catch the bastard because the torq arm was slamin' around. Now I am going to upgrade my torq arm. Who sells the best torq arm? The two I am looking at are Spohn & Random Tech. Thanks Guys.
Old May 9, 2004 | 12:42 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
Dont get edelbrocks, search for Kandied91z , he has a couple of post on hit, his broke at the weld, just moving it after it was installed
Spohn makes some high quality stuff, that would be my best bet.
Kevin
Old May 9, 2004 | 01:38 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Spohn by far.... It is a direct bolt in minus a few hiccups here and there. It depends on the car tho.
Kat
Old May 9, 2004 | 02:03 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
i ordered my spohn one yesterday, but theyre back ordered, so i wont get it for another 3 weeks, but thats because theyre the best, and you should support a sight sponsor, its the right thing to do
Old May 9, 2004 | 02:41 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Yep and it helps me keep my job!! lol
kat
Old May 9, 2004 | 02:50 PM
MdFormula350's Avatar
spohn!
a few pics on my site.
http://www.cardomain.com/memberpage/317476/9
Old May 9, 2004 | 08:52 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
kat
do it faster! i havent driven the car for like 6 monthes, im getting itchy. but i think i will put the stock one on just so i can drive it around and break the rear end in. then hopefully by the time the new one gets here, ill be able to beat on the car
Old May 12, 2004 | 01:54 PM
OneBadZ4U's Avatar
Just ordered my new Torque Arm from Sphon. Thanks fo the advice. I decided to go with Spohn because they have a set up that mounts the arm on the trans x-member instead of the tail shaft. I have a 3 week wait but, I can still drive my '92 RS(I bent the IROC Arm).
Old Jun 25, 2004 | 09:27 AM
OneBadZ4U's Avatar
Well, I got the Arm Friday June 18th. It took Five weeks!! Anyway, the part looks great. I installed it and wouldn't you know MY LS1 Driveshaft rubbed. I'll be honest. The driveshaft loop did not appear to be welded in the proper location. The loop was clearly visible looking under the car on the ground. The loop will hit every speed bump. I called Spohn. To be honest again, they were very little help. They acted as if there was nothing wrong with the part. Safe to say, I did more research on the boards and found I was not alone with this problem. I finally put the car back up in the air and took a screw jack with a piece of wood on top and bent the loop into its proper location. Everything is ok now and I feel good again. I did not damage the powder coating in any maner, that was my biggest concern. All in All I am happy, I just wish Sphon took a little more proactive aproach to problems encountered.
J-money
Jan 4, 2019 09:45 AM
New2Chevy
Sep 28, 2015 12:35 AM
luvofjah
Sep 10, 2015 10:41 AM
SG91camaro
Sep 5, 2015 10:27 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
