Lowering frontend
Old May 16, 2004 | 02:41 PM
RebelTillDeath3's Avatar
Car: 92 Camaro
Lowering frontend
Is there any quick easy way to lower the front end a little bit? It sits ungodly high for my liking and suspension isn't one of my specialties.
Old May 17, 2004 | 02:34 PM
frogmanjohn's Avatar
Car: 89 RS
Engine: 305 TBI 215,000+
many different ways to drop the front..
Order some lowering springs and just use the fronts.
Cut 1 coil off of you stockers.
buy a set of stock front springs and cut a coil off of them.
(put a big block up there)
You might be able to just find the front set of lowering springs from an off the wall place.
Or lastly, heat up your old spring with a torch and compress it a little..
Hope it helps,
John
Old May 17, 2004 | 03:07 PM
ede's Avatar
ede
what are your specialities?
Old May 17, 2004 | 08:46 PM
Car: 92 Camaro
Man, you're so e-tuff.
Old May 18, 2004 | 12:40 PM
Vader's Avatar
The only correct means to lower your vehicle is with dropping spindles. Altering the spring height will only ruin the steering geometry, specifically on turns.
Old May 18, 2004 | 12:45 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
well.......you can lower with springs....then you just have to correct the steering geometry... oh, and raise the strut mounting point to allow full travel and proper valving use.
then again, most people dont bother to do that stuff anyway.
Old May 19, 2004 | 04:51 AM
Biochem's Avatar
Car: 2002 SOM z28
I'm slightly confused. Aren't you the HS kid who co-owns a speed shop or something? Is it the Kenskustomchassis place in your sig? So you have access to people and tool to design and build custom chassis and you have to ask how to lower your car 1" on here?
Quick and simple way, just thumb through Jegs and get some advertised lowering springs and slap them in. You'll get your 1" drop and you'll never notice a difference in handling... I'd avoid heating the coils, but the other mentioned options would work well too.
Old May 19, 2004 | 08:01 AM
Car: 89 RS
i am running the eibach sportline lowering springs, with monroe sensa trac shocks. I got an alignment after i put the springs in and i love the way she rides now.
john
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
MrPackstin
Oct 25, 2017 08:09 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
92projectcamaro
Sep 29, 2015 07:07 PM
