Lining Up LCARB
Old May 18, 2004 | 04:01 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
Lining Up LCARB
I can't get these things lined up. the instructions say to make sure the back is flush with the stock bracket, but theyre nowhere near it, wtf?
Old May 18, 2004 | 08:32 PM
CaysE's Avatar
Is the suspension compressed? I'm pretty sure it has to be.
Old May 18, 2004 | 09:01 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
the rear end isnt in the car, even if it was, how would that help the bracket line up? i need to get it square to weld it. does anyone know if the adjustable lcas from spohn come at the same lentgh as the stock ones?
Old May 18, 2004 | 10:09 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Just lay them next to your stockers and adjust them so that they are. Or install the brackets with the stock LCA's and then just put the adjustable ones in later. That way everything is lined up.
Old May 18, 2004 | 11:54 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Is it better to have these welded in with the rear-end out?
Or will I be fine to have mine welded on as long as they are bolted on and flush with the back? You all have me paranoid now.
Old May 19, 2004 | 12:10 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
thats exactly my concern, is it possible to get them lined up correctly without the control arm bolted up on the car.
Old May 19, 2004 | 08:58 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I would wait until the rear is in the car. Although I didn't put mine in I am pretty sure they bolted everything up and tached it, then they pulled the LCA and starter bolt to finish off the weld.
BTW: Mine are not exactly flush with horizontal.
Old May 19, 2004 | 09:16 AM
Transmission: 4l60e
Ok I guess I will wait. I don't wanna screw it up.
Old May 19, 2004 | 09:19 AM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
I would weld them on with the rear OUT... its easy to get them Lined up...Run a magnetic angle finder on the stock backplate and then match the number to the backplate of the LCA...They dont necessarily sit flush if you will...Mine was pretty close...the important thing is getting the plate mounted at the same angle as the original... especially if you do not have adjustable LCA's
Loosely bolting the stuff up seems questionable to me given the slop in the holes for the bolt on part and the fact that when loose the rear end does not always want to sit 100% square... the load from the rear would manuipulate where the brackets were sitting..
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
romcjr
Sep 17, 2015 05:18 PM
TBRays98
Sep 6, 2015 05:05 PM
