Solid Motor & Trans Mounts In A Prostreet Camaro...should I?
Old May 17, 2004 | 12:01 PM
83_ta454's Avatar
Car: 83 Camaro prostreet
Engine: 360ci SBC
Transmission: TH400
I have an 83 Camaro prostreet that has been completely custom fabbed suspension wise, and I keep ripping up the rubber motor and trans mounts. The car does not have a torque arm any more. It is running a 12 bolt rear with ladder bars, track locater, th400 fairbanks transmission MASSIVE custom subframe connectors, and Mickey Thompson Sportsman pro tires. My question is with this combo could I safely run solid motor and trans mounts. The car has NO flex to it what so ever. Any info would be greatly appreciated
Old May 17, 2004 | 12:09 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: Solid Motor & Trans Mounts In A Prostreet Camaro...should I?
yea, thats the app they make them for... lol.. all out no comfort race cars....
if you're running RUBBER mounts though, and you were because you didnt want to run solids or a motor plate, then id just step up to Poly ones first.. they have a better chance of taking the beating....
what kind of power are you putting out?
Old May 17, 2004 | 01:14 PM
ede's Avatar
ede
run a motor plate and trash to motor mounts
Old May 17, 2004 | 03:25 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
What about poly mounts? They're pretty hard to break.
Old May 18, 2004 | 06:31 PM
Pat Hall's Avatar
If the strength difference between poly trans mounts and rubber trans mounts is comparable to motor mounts, I would have to say the poly ones would be much stronger. However, in a car built like yours, I really doubt you're too worried about the extra vibration you'd get from running solids anyway. Just make sure if you do go to solids, that you do the motor and the trans at the same time. You're not supposed to run any flexible mounts in combination with solid mounts. Doing that is a good way to break a transmission case.
Old May 19, 2004 | 09:14 AM
frogmanjohn's Avatar
Car: 89 RS
Engine: 305 TBI 215,000+
I have read in a chevy high mag a while ago that if you run solid motor mounts, you should run a poly transmission mount, not a solid trans mount. THat way it gets a little play to lessen the stress on the trans.
Old May 19, 2004 | 12:59 PM
Pat Hall's Avatar
Hmmmm, that combination may work I guess. On my 69 Camaro I was running regular motor mounts with a solid tranny mount for a little while, and I was worried that it would end up cracking the trans case, so I switched the trans mount from a solid to a poly mount just to be on the safe side.
Old May 19, 2004 | 01:38 PM
Car: '89 IROC-Z
I know first hand a few guys who have broken their transmissions due to running all solid.
Old May 20, 2004 | 04:50 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
First hand account, soild motor mounts at a minimum poly trans mounts. Just helped swap out a TH400 that turned 90 degrees in the car-70 chevelle. Alot of places will recommend a rubber mount since they flex more than the poly's which are pretty close to solid mounts.
ANybody that's is going to run solid motor mounts, when bolting up your trans and find it does not line up with the hole in the crossmember, DO NOT force it over!!! Drill a new hole/s and call it a day. By locking the motor solid and then prying over the trans you are in essence preloading the thing and it will break, not even a matter of if, but when.
This was a footbraked car too, pretty stout 468cid, but still, how often do you hear of a TH400 literally shearing off the bellhousing. In fact the bellhousing was still bolted to the block, ripped the shifter out of his hand and rasied the drivers side seat 2" when it spun around and hit the floor pan.
Soild and solid=breakage at some time.
Solid and flex= less chance of breakage. stuff still happens when you push it though.
Bro-in-law, went through 2 tailshafts on his tranny with solid tranny mount, switched to poly and guess what, still running this latest tranny.
Old May 21, 2004 | 01:04 PM
camaroracer1992's Avatar
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
dont run solids, ive ripped open like 3 th700r4 bellhousings by doing it, not a good idea
Old May 21, 2004 | 01:12 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
on a side note:
its suppost to be a bad idea to run a poly trans mount, and stock engine mounts.
i see it written everywhere, and i do believe the logic behind it...
however, i am running a poly mount with the stock front mounts, and i know of several others doing the same thing.
a solid motor/poly trans mount could work, athough id probly just run a motor plate if i had a prostreet car.
Old May 21, 2004 | 01:21 PM
IHI's Avatar
IHI
Mrdude, I've heard that same thing from tranny guys too, they say even though the poly has some flex, it is still very stiff and may not be pliable enough to prevent bad things from happening.
Against all odds, I'll be reinstalling my poly mount behind this new combo going in shortly. Just hope to christ I dont ruin a $2500 tranny I also got conflicting reports on the ultrabell as well. Some guys reccomend them since they are much thicker and stronger than a factory bell, but they say once you install one it moves all the stress down into the front pump area and the material down there is kinda thin where the bolts go through the bell and the pump.
Just another lovely debate that'll have a split descion of for and against it. Seems everything with racing you can hardly ever get a definative answer for anything since the most unexpected things can happen to anything.
Old May 22, 2004 | 01:20 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
solid mounts and a poly tranny mount. DO NOT RUN ALL SOILD. you will kill your bellhousing.
or you could opt for the 2002 ugrade LS1 mount. its like an energy, steel reinforcements and all, but its rubber. all the strenght, without the noise.
good luck
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
jharrison5
Aug 19, 2015 05:53 PM
timonator
Aug 11, 2015 09:56 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
